Better headlights and foglights
True, but I’ve been very impressed by them regardless of the stock lights being garbage. Looks are subjective of course, but I think they look good, the light output is great, they don’t blind other drivers....and the price just makes them that much better. I highly recommend them. You do have to do something if you want the fog lights to work properly and/or not get the high beam indicator on all the time, but thats no different than any of the LED options that I know of.
Have you ever been blinded by stock lights when someone is in a truck behind you? BTDT. That is an extreme case because the truck is so much higher than the C4 but I think you get the picture that SOME of the problem is that the alignment of the light isn't good. Others could be the cutoff or way over powered for street use (like I know some people who put off road bulbs).
That is the sucky part. Because of their lack of use of power, it also will trip the newer cars that were not equipped with them and the ECM reports a bulb failure. Some have rigged a resistor and others have taken the easy way out and put the in-line resistors.
