Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Reload this Page >
Anyone "know a guy" who's GM Performance L31R engine swap,350 passed SMOG Sniff test?
Old 04-10-2019, 02:51 PM
Mikeceli
CF Senior Member
Recieved 6 Likes on 6 Posts
Default Anyone "know a guy" who's GM Performance L31R engine swap,350 passed SMOG Sniff test?
Limited response in the thirdgen f body forum, so I'm visiting from CFOT! Hi Folks!
Regarding my 1989 Camaro IROC Z Vert (autotrans) , I'm thinking about swapping the 305 TPI to a 350 L31. It is a Chev Vortec long block, w/ 9.4to 1 iron head Comp, It's roller Cam is listed as .414 intake .428 exhaust lift @ .50" , Duration 191* intake 196* exhaust 111* lobe separation. I would keep ALL emissions equipment in place and functional. I am looking for actual Sniff test results, good or bad, .
.Anyone know of L31 R 350 swaps, that maintained all OE smog equipment, running clean enough to pass SMOG? I realize standards vary, from state to state, w/ cali (here) being the toughest. Thanks._____________
Mikeceli is offline
Old 04-10-2019, 03:17 PM
bjankuski
CF Senior Member
Recieved 183 Likes on 166 Posts
This should pass without any issues, I believe that is a stock 1995 to 1999 vortec truck cam. No issues at all on the sniff test.
bjankuski is offline
Old 04-10-2019, 03:38 PM
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
Recieved 611 Likes on 544 Posts
I helped a friend put and L31 Vortec long block in an '84 (with CFI) and it passed -even with out a cat.
You're aware of the mismatched intake to head flange, right? The 305 TPI lower won't mate with the Vortec heads unless you stack gaskets and drill holes. We actually drilled and tapped the vortec heads to accept the CFI intake, then cut the heads off the original Vortec intake bolts, slotted the ends so we could use a screw driver, then coated them with RTV and threaded them in, flush with the intake surface on the head, to plug the original Vortec specific intake bolt holes in the heads.
Thing ran strong when it was done though...even with the small cam.
Tom400CFI is offline
Old 04-10-2019, 04:16 PM
Hot Rod Roy
CF Senior Member
Hot Rod Roy's Avatar
Recieved 295 Likes on 277 Posts
I doubt that you can delete your cat in California. They crawl under my '84 and verify the part number on my cat. Delightful!
Hot Rod Roy is offline
Old 04-10-2019, 04:20 PM
CF Senior Member
Recieved 203 Likes on 179 Posts
You can make it work, there are also vortec lowers available.
The port velocity of vortec heads plus the velocity of the crossfire intake is probably a well matched combo. The stock intake wasn't great, I've heard switching from that to the marine intake is roughly the equivalent of porting a crossfire so it was probably an honest 300 or close to it, the marine ones were rated around there at that time.
84 4+3 is offline
Old 04-10-2019, 06:11 PM
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
Wow. That is....thorough.
Old 04-10-2019, 06:56 PM
ex-x-fire
CF Senior Member
ex-x-fire's Avatar
Recieved 65 Likes on 58 Posts
Vortec heads have no internal egr ports, you must run a tube from the manifolds to feed an egr.
ex-x-fire is offline
Old 04-10-2019, 08:40 PM
Mikeceli
CF Senior Member
Yes, I am aware if the Vortec style intake manifold requirement and was planning for it.
EGR situation makes the swap not worth the trouble, since I'm in cali. LORD, this state hates old cars!
Thank you all!
Mikeceli is offline
Old 04-11-2019, 01:22 AM
Hot Rod Roy
CF Senior Member
Correction:
But they sure do like my tax money!
Old 04-11-2019, 05:42 AM
bjankuski
CF Senior Member
Thank you all!
They will nt know by looking that the egr ports are not there, but I am not sure if the elimination of the egr ports will actally pass the nox test.
Old 04-11-2019, 04:03 PM
cuisinartvette
CF Senior Member
Recieved 1,170 Likes on 1,071 Posts
St. Jude Donor '05
I know of someone who owns a test only place & can answer your questions, is there still a requirement where its smogged no more than 30 mi from your mailing address?
cuisinartvette is offline
Old 04-12-2019, 01:36 PM
Mikeceli
CF Senior Member
Thanks, but I was only gonna do a 350 swap, if it was simple and passable. I suppose I could use a non-Vortec setup, but I doubt it's worth the trouble.
Mikeceli is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
