Oil temps on the track
Old 04-14-2019, 11:37 PM
1KHP
CF Member
Recieved 0 Likes on 0 Posts
Default Oil temps on the track
What have people seen in the track oil temps wise l98. 1991 6 speed. Beating the crap out of it on r compounds???
1KHP is offline
Old 04-15-2019, 09:10 AM
VikingTrad3r
CF Senior Member
Support Corvetteforum!
VikingTrad3r's Avatar
Recieved 395 Likes on 367 Posts
subby dubbied.
i installed the kc4 on my car for track use. was going to run mobil1 10w30
ill know may 11th what my temps are going to be
VikingTrad3r is offline
Old 04-15-2019, 06:59 PM
65Z01
CF Senior Member
65Z01's Avatar
Recieved 95 Likes on 89 Posts
Cruise-In II Veteran
I run a 160deg T-stat and engine temps rarely rise above 170s.
One day on a local cruise of the twisties in 2nd gear, we took a brief pause and I noticed that temps were approaching the 200deg mark.
65Z01 is offline
Old 04-15-2019, 09:26 PM
VikingTrad3r
CF Senior Member
thats interesting. i winder if a 150 or even 140 would help last longer on the track.
Old 04-17-2019, 03:44 PM
3D-Aircrew
CF Senior Member
3D-Aircrew's Avatar
Recieved 67 Likes on 65 Posts
It won't matter since the tstat would be open anyway unless it was a 180.
3D-Aircrew is offline
Old 04-17-2019, 04:06 PM
Kubs
CF Senior Member
Kubs's Avatar
Recieved 117 Likes on 108 Posts
St. Jude Donor '09-'10-'11
A lower temp thermostat makes the car run cooler on the street because it opens sooner and never really has a chance to get warmer. On track the water temp will reach the same equilibrium in a 20min session with a 180 stat as it would a 200, 212, or 220.
When my car was stock I constantly saw 230+ water temps and 280+ oil temps within a handful of laps. I would have to do cooldown laps within a 20-30min session to keep from overheating. Now my car is a dedicated track car with an aluminum radiator and separate oil cooler. I can run the car all day and water is around 210F and oil hovers around 230-250F without a fan. I have a single small 14" spal fan I only use when I am in line to go out or coming in off track. On track the air moving through the radiator is faster than the fan can pull anyway.
Kubs is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
