Plumbing my A/C to cool my throttle body... ehm, instead of heating it.
#41
The fuel evaporates. Guys, we have newer , DI cars that are exploiting the benefits of eval'ing fuel in the cylinder, cooling the charge. They're running higher compression, and/or more boost, thanks to that cooling effect.
So what's going on here? We get cooling from evap'ing gas in the cylinder....and we get it from dribbling it out a carb nozzle....but we miss that benefits with a port injection? I don't think so. Fuel evaporates regardless of introduce it into the air.
I know the test is slightly different due to the location of the introduction of fuel to the air...but they didn't show squat for power from a heated to a frozen intake.
You manifold coating works....I haven't tried it so I can't argue the point (nor do I want to). I'll leave it at this: I'll put my money/time toward other modifications.
As for no difference, it all comes back to the whole flow theory... for the most part, your air that's being effected by the temperature is only at the wall and the rest of the volume isn't seeing anything. If its laminar. In turbulent flow you have better mixing and thus heat transfer... that's why intercoolers have a **** ton of tubes to mix it up instead of just being a big *** open box.
#42
Pro Mechanic
It's not about "storing heat". The heat of vaporization that goes into vaporizing the gas in a carbed intake and the water/meth injection (which is non-flammable, btw) on a port EFI intake cools the intake charge, making it denser before it goes into the cylinder. Port EFI does this too, but because it happens in the port instead of the plenum, you don't get the full benefit. the port restricts the flow before the intercooling effect. I would think direct injection would see even less intercooling..
You don't get the same cooling with an injector period... the only reason it works with a carb is because of the excess fuel present and vaporizing in the entire plenum. Any boosted DI car still needs an intercooler. It's not a flaw with injectors but rather an example of how wasteful carbs can be.
The fact is, the fuel evaporates in either case, and proof of that is that we get good combustion and efficiency. If the gas stayed in a liquid state w/ port injection, you'd have incredibly poor combustion, or none at all.
No. Intercoolers have a **** ton of tubes to increase the exposed surface area of the air to the aluminum. Turbulence is created by making the ID of each tube rough or textured.
#43
Pro Mechanic
#44
But it DOESN'T. Which is the precise reason OEM's have made the move to it....and made corresponding jumps in compression, boost or both. Ya "lecture" me on how gas evaporates...then don't even know it's effect in DI applications? As I said before, if gas is evap'ing in the cylinder in a DI engine (and it is), and it's evap'ing in the plenum w/a carb...then how can it not w/port inj....which is right in between both?? The fact is, it does evaporate, and proof of that is that we get good combustion and efficiency. If the gas stayed in a liquid state w/ port injection, you'd have incredibly poor combustion, or none at all.
Say what? So, if you tune the ECM on a port EFI system, to "run rich"...then you'll get the same cooling? Or if you jet a carb lean, you won't get it? Come on.
And I never said you don't get the cooling effect, I said it isn't the same.
Now that could also be wrong... I've been known to screw up a lot. That's why I'm going to school for engineering and am not presently an actual engineer.
So let me just leave it at this, does any of this **** actually make a meaningful difference? No. Probably not in any way shape or form.
#45
Pro Mechanic
I totally
84 4+3 (04-20-2019)
#46
Pro Mechanic
Did you watch the video? No, ya didn't.
If you refuse to learn, no amount of factual info that I share, will help. FYI, "ports" aren't the only restriction in an engine.
#48
If you're so bent on proving someone wrong that you refuse to learn...
#49
Pro Mechanic
This has been a Closer Look!
#50
You guys can argue theory theory theory all you want. I've done the epoxy mod in real life. There is benefit to cooling/not heating the intake air in the manifold plenum. In the case of a basically stock gen 2 LT1, about two tenths in the quarter mile. And the kicker is, it's real easy for anyone to test. All you need is a bag of ice at test-n-tune night.
#51
Pro Mechanic
Fair enough. I haven't tried it, so I'll take your word for it. Epoxy.
#52
back in my Mustang days, a lot of sixers(that's what we used to call those with V6) had ideas like that.
Run AC straight in to intake for cooler denser air, run leaf blower in to intake and so on...
got nice chuckle out me...
#54
Pro Mechanic
1. I don't doubt that ice works. I'm sure it helps. 2/10? IDK about that. Maybe.
2. I'm not sure that an insulated intake is the same as a COLD intake. Maybe.
3. I'd be more interested in TRAP, as trap tells the HP story.
4. My drag track just closed this pas fall. For good. No more drag track in SLC, until UMC hopefully (Fingers crossed!) builds one.
5.Engine Masters just did that test...on a dyno and picked up 5 hp on an 800 hp engine.
BUT...if we get a drag track here again, I'll try it.
84 4+3 (04-23-2019)
#55
A couple things:
#56
Pro Mechanic
Thanks. It's a mixed bag. I'm totally bummed b/c I love drag tracking my car.
OTOH....it was the WORST RUN, most frustrating frickin' track I've ever been to. The place was a mind-****, waste of time, every time I went. So 1/2 of me is glad they're gone.
RMR SUCKED...DONG
RMR SUCKED...DONG
