what is this stuff on my oil pump pickup screen???
Oil Producer
haggis how would it work? like order a set of bearings same size or slightly undersized? i have a lift so i could do this easily. and ive head stories about new bearings making engines last longer.
its new territory for me.
is it as easy as pulling a bearing cap and putting a new one on again?
Your call but I would like to have seen how much bearing material is left on the mains and big end bearings before you button it up, replacing the bearings at this point if the crank is not too bad could extend the life of the engine considerably. From what you have found so far I would say the PO was "allergic" to doing oil changes! Reminds me of an ex sister in law who proclaimed that the car she had at the time went better when the little red light on the dash was flashing (OP light, oil not showing on the dipstick).
Oh yeah, I did rods and mains in mine. The biggest things you have to worry about are not scratching the journals on the crank while doing it, and getting the caps back on in the proper orientation. You can mark them with a punch or whatever before removal to help here. If you get a rod cap on backwards, it will do damage..
But, aside from that the bearings look like this:
They are inserts with a tang to locate them, and you simply slide the old ones out and the new ones in. Most of them (and the one in the pic does, as you can see the "std" marking) are marked for size right on the backs. If you want to double check (I did) you can put a strip of plastigauge in the bearing torque it, and it will compress and then you compare their scale with the width of the compressed strip, which gives you the oil clearance. It's real simple.
The mains, you have to lower the crank just a little. The rear main is the thrust, so you put it in and align it by gently prizing the crank back and forth and torque it down.
Nothing hard about any of it for a quick overhaul, as long as you get caps back on in the proper orientation and don't scratch crank journals. (Use some fuel hose on the rod bolts to prevent damage and take your time.)
I did rings, heads and a cam too.. Right in the car!
Oil Producer
so just buy std? or buy them at .001 undersized to tighten them up a bit ?
or are you saying buy std and then a couple smaller ones and use plastigauge to put the right size in? like u need inventory of multiple sizes beforehand?
Getting the upper half of the main bearing can be a little more difficult. rotate the crank shaft and sometimes it will roll right out; if not get a brass cotter key, hammer the head flat, insert the cotter key into the oil hole in the crank and now rotate the crank; the flattened head of the cotter key will rotate the bearing shell right out. Important; one side of the end of the bearing shell has a small tab rotate the crank so that the tab end rotates out first.
You should note that the #5 main bearing also serves as the crankshaft thrust bearing.
installing the new bearings is just the reverse.
The rod bearings are even easier. just do one rod at a time and make sure that the lower rod end cap goes back on in the same way as it came off.
If you want to double check the clearance, use plastigauge..
similarly, on the rods, make sure that the crank is rotated so that its forcing the rod up.
Oil Producer
thanks for taking the time guys. i think ill go ahead and do this.
Oil Producer
So Guys, I suppose i need to do the whole cardboard box with holes drilled in it thing so i can stick the bearing caps and rod caps back exactly as they came out? same bolt goes back into the same hole? I'm going to pull the pan again (re-useable gasket, no worries) and pull the bearings off and order replacements. thnx for pushing me.
Sort of.. You are going to want to mark them to return them to both the same position and the same orientation on the engine as they were.
The mains are honed to be aligned and they need to go back exactly as removed. The rods are worse, because the edge away from the common area of the journal has a chamfer turned on it, and the rod has a corresponding chamfer on one side to accommodate it.
Get that backwards and you will do damage.
So, number the mains front to back and side to side, and put the rod caps back on the same rod and in the same orientation as they were removed.
Oil Producer
^^ Thank you Dogs!!!
today i replaced the ujoints in the driveshaft and will be reinstalling the driveline.
then ill drop the pan and do the main and rod bearings.
ill be re-reading all the tips in this thread and it’ll take me a while but if i hit any snags ill post the questions here.
