I recently had my blower stop working on any setting other then low. So, today I replaced the blower relay with AC Delco part #15-81743. Everything seems to be working fine but, after approx 15 sec or so it snaps the AC fuse (25 amp) in the passenger side fuse box. Can somebody point me in the right direction or
tell me what else in on the AC circuit? I have a FSM so I can reference that if need be.
Thanks in advance and have a great Easter.
Blower shorted or wire to it grounded. Unplug wire to blower and see if fuse blows. A circuit breaker short finder would be cheaper than continuously blowing fuses.
The a/c circuit is on pg. 8A-130 in your FSM. If you put the function switch in the VENT position, does the fuse still blow when you turn on the ignition? If the fuse doesn't blow, can you select all of the fan speeds without blowing the fuse?
This test will tell you whether the problem is in the compressor circuit or the fan circuit.
Ok, so as an update, after a little messing around, it seems to only blow the AC fuse when the blower gets set to its highest setting. 1-3 seem to be fine.
Very interesting! If the a/c works normally, and the VENT position makes no difference on blowing the fuse, it can only be that the two wires that connect to your fan speed relay coil are backwards. When the fan speed switch is in the HIGH position, the power for the fan motor does NOT go thru the a/c fuse, so the fan motor is NOT the problem!
I can't find the electrical diagram for that relay, but the only reason for my answer is that there must be an anti-arc diode inside that ACDelco 15-81743 relay. You can test for this with a multimeter by measuring the resistance of the relay coil, then reversing the two test leads. Are the two resistances the same, or different? If they're different, your relay DOES HAVE the anti-arc diode, and you MUST reverse the two wires to the coil. By the way, having the anti-arc diode in the relay is a good thing! It's too bad ACD doesn't tell you about that, but they think you're plugging it into your 1981 Pontiac!
