Swapping to a one piece rear main?
Just like the title says.
I have an 84, with the typical split main seal, my plan is to drop an 1997 block into the car with a one piece. The car is a Doug Nash 4+3, so I know I will need the flywheel and clutch from one of the newer cars (86 to 88 if I'm correct) but...are there any other surprises that I need to be on the lookout for??
Thanks for reading.
Thanks for reading.
When you say you are using a 97 block, I'm assuming you are talking a LS engine then. What are you planning to do for bell housing, motor mounts, electronics etc?
If you meant a 96, are you putting in a LT block. Again what are you planning to do for intake, electronics etc?
you are putting a 97 vortec in it? let me know how it goes, i have thought about that as an option also.
i hear you can make 450 hp with a cam change everything else stock with those
