Blower motor not coming on (87 coupe)
Hi,
I noticed that my vents weren't blowing any air.
At first I thought it was just gonna be dirt in the squirrel wheel, but when I removed the blower motor assembly it was still white, clean and spinning well.
Before reattaching the assembly I connected the connector that goes in the right of the motor, placed the assembly on top of the engine (so I could see it from the driver seat) and started the car.
No matter what AC/Heater setting, and fan speed, it didn't spin.
I unplugged the connector and tested a multimeter to the sockets, but could get any reading.
I have checked all fuses, and they're all whole.
Should I slice up the cables to the connector and check if I get a reading straight from the wires, or where should I start trouble shooting this?
The cold/hot slider seems to be working as I can feel a temperature change near the vents, and I can hear clicking from the engine bay when sliding through the different modes.
hard to determine EXACTLY what the problem is without proper diagnostics. do you have a FSM? had a similar problem in my 85 awhile back - turned out to be the HVAC select switch. check out this thread - https://www.corvetteforum.com/forums...er-speeds.html --
Thank you for your tip, I'll have a look at it.
For a while I thought it might be the resistor. But after taking it out last night I can't say that I see anything burnt on the coils or pints (the black stuff is just dirt).
I guess the search continues.
The resistor cannot be checked by a visual inspection, at least in my opinion. Just changed one in my truck last fall that only worked on high, though looked fine it wasn't. You can try ohming it but for what they cost it's better to replace to test. The fact you have no speeds implies it's not the resistor. I'd check the fuse and wiring if you have no power at all to the fan.
I managed to trace the problem to the relay near the blower motor. I could hear the old one click when turning the AC on, but I guess it just didn't operate the way it should.
With the new relay my blower motor comes on in Lo, lo-mid and hi-mid.
However, when I put it in "Hi" the fuse blows.
I even tried putting in a 40A fuse for laughs, instead of the stock 25A, and it blew.
I found that the yellow wire going to the relay was skinned and showing lots of copper, so I wrapped that up in electrical tape. I can't see where else it shorts. But I guess that's a trouble shoot for another day.
Thank you all for your help.
