Bolt sizes in FSM
Old 05-06-2019, 05:50 PM
az_camaro
Junior Member
az_camaro's Avatar
Default Bolt sizes in FSM
Where in the Factory Service Manual does it refer to the bolt size used for a specific application/part install?
I'm trying to put my car back together after the person who took it apart just dumped the bolts in a Rubbermaid tub all mixed together.
All help appreciated!!!!
az_camaro is offline
Old 05-06-2019, 08:47 PM
1971chevroletnova
Junior Member
good luck! mine in PDF format only shows "bolt" seems to be a mix of metric and US on the engine at least
1971chevroletnova is offline
Old 05-07-2019, 02:59 PM
ctmccloskey
CF Senior Member
Support Corvetteforum!
That is good information to know! Thank you ihatebarkingdogs!
I used to have a couple early 1960's British motorcycles that used Wentworth Threads (sp?) I used to have three tools sets to be able to work on my early British Toys. Then I learned about Lucas, The Prince of darkness and his connection with British Engineers and gave up on British cars and motorcycles.
In the assembly manual they list out the bolts used where and when. I have always wondered why they don't make any assembly manuals for the C4 Corvettes. They are very handy.
Best Regards!
Chris
ctmccloskey is offline
Old 05-08-2019, 08:30 AM
Randy M
CF Senior Member
Randy M's Avatar
Chris,
I agree, it would be nice to have an assembly manual for the C4. Unfortunately the C3 was the last assembly manuals they offered.
Randy M is offline
ctmccloskey (05-08-2019)
Old 05-08-2019, 09:14 AM
NavAir
CF Senior Member
NavAir's Avatar
Probably because the manufacturer wanted to discourage non-dealer mechanics (including DIYs) from sourcing fasteners from suppliers other than the (way overpriced) dealers. If you needed to get a part, you would go to the dealer, who would look it up in the parts manual, and order by part number (not SAE or DIN designation).
NavAir is offline
Old 05-08-2019, 02:11 PM
Randy M
CF Senior Member
Randy M's Avatar
Well, I am thinking that, no assembly manuals, and assembly manuals that exist and are not available for us to buy is kinda the same thing.
Randy M is offline
Old 05-10-2019, 07:41 PM
az_camaro
Junior Member
az_camaro's Avatar
Thank you for the responses. Knowledge is a powerful thing
Old 05-13-2019, 08:02 PM
Joe C
CF Senior Member
in most cases, the factory parts and illustration manual, will list the specs of the hardware. here's a simple case showing the alternator mounting for a 1984, L83 corvette. in addition to the FSM, parts manuals are a must have. some of the abbreviations in the description can be a bit challenging at times. hard copies are available thru 1993 (last printing), 94-96 (i'm thinking) on-line .pdf.
note mixture of unified national thread and metric.
Joe C is offline
Old 05-14-2019, 05:35 AM
Joe C
CF Senior Member
engines (long blocks) are assembled in national fractional. anything that bolts to the engine, e.g., accessories, will be metric.
Best Regards!
Chris
"whitworth" - major difference between national and british whitworth is the thread profile - in most cases unified national hardware will have a "V" cut @ 60 thread, whereas, whitworth are smooth cut at 55. I have an old 74 Norton Commando 850 - in a pinch and in non-critical applications, I've swapped out whitworth for national. they seem to torque OK, however, I only do this if it's my only option, and always with blue thread locker.
https://www.rustmag.com/gear/2018/1/...thread-systems
only partially true - see my post on the parts and illustration -
speaking of other suppliers, I've purchased small quantities from the Bolt Barn - they are fleabay vendors/sellers. stuff appears to be decent quality, along with decent pricing. here's an example -
https://www.ebay.com/itm/5-M10-1-5x3...IAAMXQgb1RP9LZ
Joe C is offline
Quick Reply: Bolt sizes in FSM
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
