1994 C4 coupe left front / sill speaker
Can the right front speaker "components" be use in a left front front speaker "frame"?, i'e' use a right speaker to build a left side speaker? Can not find a left front speaker but can locate a right speaker. Thanks Bob
Last edited by bfigueroa; 05-22-2019 at 08:38 AM. Reason: deleting messed up photo
The image you tried to attach is a mess.
The speaker part #s are the same left to right, and you can probably order new speakers from Bose directly if you have the part #. Somewhere in an email I think I have that info if you could use it.
Thanks for the reply. Agree, picture is a mess. Tried to correct but the edit "button" was not available, or at least I could not locate. My research indicates that the left speaker OEM part # is 16166481 and the right is 16166471. Question: are the 2 speakers interchangeable? Thanks again, Bob
I just want to make sure before I lie to you, you are referring to the Bose system correct? If so, there are 2 speakers in each enclosure in the front.
5" "Full Range" Bose Part # 132498
3" (Maybe? I forget the size) Tweeter Bose Part #133620
I don't have the GM Part # on hand, but they're probably in the FSM. I'll look and see if that info is in there after work.
Speakers do interchange left to right on the Bose. Only difference is the enclosure.
