Help Finding Oil Leak in Front of 96 LT1
I have a small amount of oil dripping from the crankshaft position sensor. I'd appreciate any tips to try to locate the leak. I'm thinking it's either the water pump drive, crank seal or just the crank sensor.
Does anyone have any tips on how to look at the crank seal and water pumps seal. Looking from underneath it's really hard to see anything. I've tried to reach up and feel around the crank but it's pretty hard to tell if its wet.
Any ideas would be greatly appreciated.
Florescent dye is available. It can help identify small leaks. It at can come in a kit; with black light and tinted glasses to enhance ability to see dye.
water pump replacement solves oil leak
Not likely going to help with your specific problem, but my 95 LT1 has leaked a bit of oil since I got it five years ago. I keep a flattened-out cardboard box underneath it, and change as required.
First tech to look at it said he could replace all the seals for about $2500, but said it'd probably be leaking again within a couple weeks...just the nature of the beast. So I let it go.
It's also leaked a small amount of coolant as long as I've had it, but until taking it in for its spring once-over this year, no one identified the water pump as the source of that leak. As for the oil leaks, they said it needed new oil pan gasket, timing cover gasket, new "distributor" ("they all fail, so we might as well replace it while we're in there") etc., etc.. Estimate was nearly $3000 (canadian $)
Anyway, I said just do the water pump for now. I've had the car back for a month -- no coolant leak and SURPRISE -- there's no more oil dripping onto my garage floor anymore. Just got lucky, I guess.
My 96 with 18000 miles had the same leak. It made a pretty good mess. You can still get the o-ring from AC Delco (it was about $13). Replaced and totally fixed it.
