C4 Rears on a C7 (Yes...you read that right)
Old 06-06-2019, 10:23 PM
Casey Clark
CF Member
Casey Clark's Avatar
Default C4 Rears on a C7 (Yes...you read that right)
Howdy,
I am actually getting a set of MT ET Streets on C4 Wheels for a song for weekend strip use. I've read up a bit but I'm not sure if I will need a spacer or not. Current owner had them on a C5 and needed a spacer. He *thinks* the wheels are from an '84 if that helps.
They will be going on a 2014 C7 Stingray with the 19x10 rear wheels with the +79 offset.
The tires on the C4 Wheels are 26x11.50x16
My C7 tires are 285/35/19
Pic of wheels attached.
Casey Clark is offline
dizwiz24 (06-07-2019)
Old 06-06-2019, 11:32 PM
MatthewMiller
CF Senior Member
MatthewMiller's Avatar
I don't know much about drag tires on narrower wheels, but that's a wide tire for that rim. As far as spacers being needed, that doesn't make sense. These wheels already have way less offset than C7 wheels: if 8.5" they only have 32mm offset, and if 9.5 they only have 38mm. Compare that to the 79mm of your stock 10" wheels, there's almost 2" more offset (to the inside) on your stock wheels. And spacers would subtract from the offset even more. They may in fact fit inside the fenders of a C7, especially if they are the 8.5" wheels. It will be close as to whether or not they poke outside the fenders. But you really shouldn't need spacers!
MatthewMiller is offline
Old 06-06-2019, 11:55 PM
Casey Clark
CF Member
Thank you but now I am reading up a bit and it looks doubtful if they will clear the brakes on a C7. Luckily I donít have a Z51, but even my base modelís brakes might be too big.
Old 06-07-2019, 07:41 AM
MatthewMiller
CF Senior Member
That's always tough to know without a test fit.
Old 06-07-2019, 10:48 AM
383vett
CF Senior Member
383vett's Avatar
No way 16's will fit on a C7 without a spindle lowering kit. Here's a picture of my 16Z with 18" wheels which barely clear the brakes.
383vett is offline
Old 06-07-2019, 02:13 PM
vetteLT193
CF Senior Member
Support Corvetteforum!
The rear brakes are the same on the C7 Z51 or not (other then the Z51 having slotted over ventilated rotors). The rotor size on the rear is 13.3 inches by itself. I can't imagine clearing that with a 16 inch wheel when you add another couple inches for the caliper.
The smallest I have heard of working are 17" Trans Am wheels or 17" C5 front wheels.
vetteLT193 is offline
Old 06-07-2019, 10:17 PM
dizwiz24
CF Senior Member
Howdy,
Nice putting C4 parts on a C7 (to make it go faster).
my dream is to buy a C7 and swap out the C7 LT1 for a late c4 optispark LT1 - just to prove the point that theres nothing magical with the LSx line (post SBC) engines !
dizwiz24 is offline
Old 06-09-2019, 03:02 PM
Pwnage1337
Pwnage1337's Avatar
That would take the value of the car and cut it into nothing
Pwnage1337 is offline
Old 06-09-2019, 03:28 PM
dizwiz24
CF Senior Member
Its not about value.
its about proving a point.
the lsx series (and its new direct injected counterparts) are not really any different than the SBC. Cost taken out of the picture / its only real benefit is a weight savings.
it doesnt have dilithium crystals, warp drive, etc.
you can do a max effort build on either platform. If you make 1400 rwhp on an lsx motor and 1200 rwhp on an optispark lt1 - so what.
Note that supercharging , fuel, and tuning technology has evolved since the Optispark lt1 was the newest motor out there. All that same technology being applied to lsx engines can easily be retrofitted onto SBC
Theres a new revolution in place - electric cars. Those will likely be unmatchable by gasoline engines .
dizwiz24 is offline
Old 06-09-2019, 03:47 PM
slow_zo6
CF Senior Member
slow_zo6's Avatar
I remember when trolling used to mean something.
slow_zo6 is offline
Old 06-09-2019, 04:03 PM
Pwnage1337
Pwnage1337's Avatar
I just read an article that said GM is going to cease all R&D on new engine technologies and start building C4 era LT1s again because they realized they screwed up by stopping production.
A long meeting was held with the board of directors and they all unanimously decided that the OptiSpark and it's imminent failure when it finds out it's going to rain next week was the best path forward for the company.
The following 2 users liked this post by Pwnage1337:
dizwiz24 (06-09-2019), slow_zo6 (06-09-2019)
Old 06-09-2019, 04:29 PM
slow_zo6
CF Senior Member
slow_zo6's Avatar
Rumor has it the C7Rs currently being used by the Corvette Racing team have Gen II LT1s In them.
slow_zo6 is offline
Old 06-09-2019, 04:43 PM
Casey Clark
CF Member
This thread turned into gold! lol.
I ended up picking up a set of 18" C6 GS knock-offs with NT05rs on them. 305/45/18 and they clear but do poke a little.
Old 06-09-2019, 07:13 PM
dizwiz24
CF Senior Member
Love it.
you put c4 parts on your c7 to make it faster 🙌
thank you for posting this
dizwiz24 is offline
Quick Reply: C4 Rears on a C7 (Yes...you read that right)
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
