1992 C4 Gauge Cluster no working
Old 06-09-2019, 04:36 AM
newcamaroguy
Junior Member
Default 1992 C4 Gauge Cluster no working
Hi everyone i am having issues with my C4 cluster not working properly.
I have the check gauges light on and my OIL pressure, OIL TEMP, and TEMP F gauges do not work.
The voltage gauge works and so does the rpm gauge. The LCD works fine too and does report engine temp on there.
I have taken it apart and tested the gauges individually with a power supply and they do move. The circuit board looks fine too and i checked all the traces on the board for the cluster and they have continuity. I cleaned the connectors also and they still do not work. I believe the gauge cluster is working and there is another issue. Anybody have any ideas what to check next?
I tried grounding the temp sensor connector as i read on another thread but the gauge still did not move as they mentioned it would.
any help will be appreciated Thanks
newcamaroguy is offline
Old 06-09-2019, 07:43 AM
hcbph
CF Senior Member
hcbph's Avatar
When I had problems with mine, I sent it to batee.com and had it repaired. Well worth the time and money to get it done. There's a wealth of info on the website also along with parts for those wishing to fix it themselves.
hcbph is offline
Old 06-10-2019, 10:58 AM
old_vette
CF Senior Member
If you determine your BCM/CCM is at fault, I have a 92/93 CCM I used as a backup that is available and for sale.
Jack
old_vette is offline
Old 06-10-2019, 11:30 AM
3D-Aircrew
CF Senior Member
3D-Aircrew's Avatar
Bryan at Batee has a lot of videos for different repairs:
3D-Aircrew is offline
Quick Reply: 1992 C4 Gauge Cluster no working
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
