AFR composite intakes? Can't find 'em...
Old 06-10-2019, 12:58 PM
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
Default AFR composite intakes? Can't find 'em...
Anyone know why I can't find these on Summit or Jegs' websites? Did they stop making them already? Or more likely, am I being blind?
Tom400CFI is online now
Old 06-10-2019, 01:13 PM
Aardwolf
CF Senior Member
Aardwolf's Avatar
Aardwolf is online now
Old 06-10-2019, 02:09 PM
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
Yep. Now, where is the button that says, "Add to cart"?
Old 06-12-2019, 08:30 AM
dizwiz24
CF Senior Member
Do they make them for LT1? They make heads for LT1 why not intake (instead of the lousy fitting edelbroc k air gap lt4 intake)
Why just blow thru single plan carb style?
dizwiz24 is offline
Old 06-12-2019, 09:03 AM
drcook
CF Senior Member
drcook's Avatar
Summit has them marked as "Not Available"
https://www.summitracing.com/oh/part...4801/overview/
drcook is offline
Old 06-12-2019, 10:18 AM
dizwiz24
CF Senior Member
Its stuff like this we need to defeat lSx
dizwiz24 is offline
Old 06-12-2019, 11:23 AM
rklessdriver
CF Senior Member
rklessdriver's Avatar
To be honest, my customers experience with them has been not good. AFR has replaced the upper spider 3x and the lower valley plate 4x for one guy..... He finally said screw it and put a Holley 300-110 on his engine (383 SBC in a low 10 sec 73 Nova)..... Another oval track guy that I built an engine for has replaced his 2x so far..... these intakes seem to work fine for a while then start leaking like SOB after they get some heat cycles.
The power is OK but not better than any other good 23* SBC single plane like the 300-110, 2925 or HV1000..... I personally won't ever use another one.
Will
rklessdriver is offline
Old 06-12-2019, 12:14 PM
cuisinartvette
CF Senior Member
Received 1,242 Likes on 1,134 Posts
St. Jude Donor '05
like the 300-110 and 300-25 I dont think the Dornton piece is made anymore.
Have 2 new in the box in case...look up Holley Performance on ebay sometimes they come across a return or blem. Got both of mine dirt cheap
cuisinartvette is online now
Old 06-12-2019, 12:23 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
9-11# lighter than aluminum intakes???
Damn.
69427 is online now
Old 06-13-2019, 12:02 AM
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
That's what I've seen too. Bummer.
I was interested in it for the weight. I hear what rklessdriver is saying...that's probably why it's off the market....but man, it looks so good! O-ringed, divorced from the coolant, light, and it DID make more power than an aluminum intake in a couple tests I found.
http://www.superchevy.com/how-to/eng...s-single-plane
http://www.superchevy.com/how-to/eng...polymer-intake
https://www.hotrod.com/articles/ccrp...manifold-test/
Quick Reply: AFR composite intakes? Can't find 'em...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
