Rubber whip antenna?
Anyone replaced the buggy electric antenna on their C4 with a modern rubber whip?
I'd think a modern antenna would have at least as good reception (if not better) as our old fashioned "Up & Down Stick". LOL
Gotta be a reason - or 10 - that nobody uses the old fashioned ones anymore ...
If my stock motorized antenna ever breaks, I'd replace it with something like this I found on Ebay. Bet the reception would be the same, and cost way less than replacing the OEM antenna. Of course there would be some fabricating/modifying to do before this would work.
https://www.ebay.com/itm/Retractable....c100005.m1851
I have this on my C5. Best shorty antenna I ever had Perfect reception.
https://www.theantennasource.com/CHE...8-2004.html#5C
Finding a BASE is apparently the issue.
I'm looking for something that could be used on a C4, specifically a convertible.
Various masts (like you use on a C5) won't cut it, there is no base on the C4.
Still looking ...
Still looking ...
-- Joe
What ever type you buy, stay away from the stubby ones that look like a lonely lady's "Lil' Friend"
I thought I heard that someone took the motorized one out and patched the hole and painted to match. For an antenna, they use one that is stuck on to the glass and amplified. I tried that eons ago and got pretty good results.
I was hearing about those hidden antennas.
my current plan is to fill the hole, and install it either under the dash, or under the trim of the b pillar.
Here's the best "fix" for the O.P.'s problem:
OR GET REAL FANCY WITH THIS ONE:
Gibbles (02-22-2020)
Sign me up for the fancy option!
how dows that baby shark song go again?
