85’ how much to fix?
My car won’t start. The vacuum lines need to be replaced and so does the battery.
i don’t know if it won’t start just because of the vacuum lines, but that’s just one of the issues I know of.
What, on estimate, would be the minimum cost to get my car running again; plus what would be the maximum id pay.
thansk!
thansk!
Your question has many side roads, and you don't give enough information. Basically a battery from auto zone $135.00+-. Vacuum lines not allowing car to start highly unlikely would need to be Huge.
You need to answer these questions first.
1, do you have fuel pressure (35psi +-) hopefully holding bit with fuel prime cycle of key
2, do you have spark when cranking
3, do you have injector pulse, Noid light can be rented at auto zone
So...
Looking at your posts, you already have a new battery as of last year?
Already replaced the fuel pump, but have no voltage?
Honestly the posts go all over the place...
No solid troubleshooting (as in not focusing on the issues at hand), and they all appear to be related to the same issue?
Us whipping out a number would be a disservice to both you and the mechanic.
Furioso (06-28-2019)
