What valve springs should I get.
Old 07-03-2019, 02:36 AM
Mason123
CF Member
Default What valve springs should I get.
What valve spring size should I get. Single or dual and is there any specific size?
1985 corvette.
Mason123 is offline
Old 07-03-2019, 03:32 AM
Joe C
CF Senior Member
1985 corvette.
installed Elgin Industries service replacement Z28 (type) springs, retainers, and locks in my (stock) 85 when I did the valve job. about 12-13K miles (3 years) - no issues to date.
here's the specs...
The Z28 springs are stock outside diameter and can be used as a drop-in fit in many 1955-1993 small block Chevy V8 cast iron cylinder heads. They work great for stock, towing and most mild performance cams and work best with cams up to 0.500" lift. Many sellers claim these springs can handle up to 0.550" maximum lift but I personally don't believe they have enough spring pressure to handle more than 0.500" lift.
Valve Spring Specifications:
  • Spring Part Number: RV943X
  • Outside Diameter: 1.260"
  • Inside Diameter: 0.785"
  • Closed: 114 lbs. @ 1.710"
  • Open: 318 lbs. @1.210"
  • Coil Bind @: 1.160"
  • Spring Type: Single with damper
side note - Elgin Industries is a tier one supplier to GM. it could be the original OE springs were Elgin parts (???). bought mine thru fleabay (seller - classic engine supply) - current price around $66-shipped (spings, retainers, locks) https://www.ebay.com/itm/New-Z28-Sty...37fd%7Ciid%3A1
Joe C is offline
Old 07-03-2019, 03:45 PM
Kevova
CF Senior Member
Kevova's Avatar
New cam go with cam suggested springs and retainers. Increased spring rate can overtax stock retainer leading to a "bad day." Stock l82, there is no benefit to having stiffer springs than you actually need.
Kevova is offline
Old 07-05-2019, 07:38 AM
BLKMAMBA
CF Senior Member
BLKMAMBA's Avatar
Springs are directly related to cam selection. call or email LLoyd Elliot from Elliot Portworks, he is awesome and extremely helpful.
BLKMAMBA is offline
Old 07-09-2019, 03:18 PM
tcinla
CF Senior Member
Support Corvetteforum!
tcinla's Avatar
If you get a c7 or c8, problem solved... If they're not too 'ugly'.
1985 corvette.
tcinla is offline
Quick Reply: What valve springs should I get.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
