Easy diagnosis 93 A/C controler
Old 07-09-2019, 06:04 PM
radar502
CF Senior Member
radar502's Avatar
Default Easy diagnosis 93 A/C controler
I have traced my A/C problem to either the A/C (on button) or the controller or ECM. I looked at my manual and the test is very complicated to figure witch one it is . I have NO signal coming out of the ECM . Anybody know of a short cut test to figure out witch one it might .. Thanks ..
radar502 is offline
Old 07-11-2019, 09:30 PM
rusty76
CF Senior Member
rusty76's Avatar
I posted on your other thread about this problem asking if you've pulled the codes off the controller? I was getting all kinds of symptoms with mine and when I checked the codes it came down to low refrigerant. Charging the system has fixed it - so far.
rusty76 is offline
Old 07-11-2019, 09:33 PM
radar502
CF Senior Member
radar502's Avatar
Thanks , I paid a guy to charge the thing >> is it full ??? Am going to a shop Sat. to have it rechecked .
radar502 is offline
Old 07-11-2019, 10:00 PM
pcolt94
CF Senior Member
pcolt94's Avatar
You need to have the compressor operational to charge a system. If you get the compressor running by some other method you might be able to charge it and get a handle on the charge.
pcolt94 is offline
Old 07-11-2019, 10:50 PM
rusty76
CF Senior Member
rusty76's Avatar
In my case because the refrigerant was low the clutch wouldn't cycle to allow a charge. A friend who has the requisite gauge set and refrigerant (134a) static charged it as much as possible then we pulled the relay and 'jumped' the pins on the clutch relay connector (relay on my '93 was on the inside of the passenger wheel well) to get the clutch engaged then he fully charged the system. Again, it all started because I found the low refrigerant code (09) when I downloaded the codes from the A/C controller. I have the C68 auto climate control. You can find the procedure to download the trouble codes from the A/C by searching here on this forum or on Google.
rusty76 is offline
Old 07-12-2019, 09:46 AM
radar502
CF Senior Member
radar502's Avatar
Thanks , the system was and I say was supposed to have been charged ???? I have NO codes ??? I an going to recheck the charge today..
radar502 is offline
Old 07-12-2019, 11:19 AM
rusty76
CF Senior Member
rusty76's Avatar
If your reading in your manual Book 1 section 1B then you're doing what I was doing. You're right it IS complicated. With my issue it looked like I had the problem with the controller folks have posted about here with the buttons not making contact but once I recharged the system all that pretty much went away.
I just did a search in Book2 of the manual on 'compressor' and got a lot of hits. The first was a diagram of the ECM and the Quad Driver Module which has a relationship to the A/C clutch. I don't know all your symptoms nor what you've tried to date so I can't say if it would be useful or a waste of your time.
If I lived up the street from you I'd be there helping you even if all that meant was holding your beer. Maybe someone here on the forum that has better knowledge/experience with the A/C will join in the discussion?
rusty76 is offline
Old 07-12-2019, 11:22 AM
radar502
CF Senior Member
radar502's Avatar
https://www.corvetteforum.com/forums...o-make-it.html Thanks . I have all the info here on what I have done to the A/C system ..
radar502 is offline
Quick Reply: Easy diagnosis 93 A/C controler
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
