Track driving with an automatic....
It seems like it could really simplify things. Getting in the right gear is a bit tricky with a manual sometimes. Especially if you are new to a track. You would have one less thing to concentrate on while going around the track. I usually get out to the track a couple times a year with my "other" cars. It wouldn't be a competitive road racer. Still looking for that perfect C4 vette that can do it all.
You might also post in the Autocross and Roadracing forum here, I bet some of the guys there run A4s.
When I have the opportunity I go for 3rd and can top 100.
But that's on public twisties!
Can't run it on a LEGAL track, I don't have a roll bar!
jack
Now, that said, you should REALLY consider evaluating the health of your tranny. Track running isn't hard, but SHIFTING is. My C4 doesn't have a tranny temp sensor, but my C5 does. The C5 complained of tranny fluid overtemp about 10 to 15 minutes into a track session when I shifted it a bunch. It stopped doing that when i just left the tranny in second. I could do that with the LS1 (2nd gear's good for 20-94 mph), you can't really do that with the L98.
But ignorance was bliss. ;) I pummled that tranny for a good 30,000 miles before I decided to have it rebuit (I did't fail, I just figured it was time).
Sure like to know!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
thanks...
the rago.......
:eek: :eek: :eek: :eek:
I did lots of road race track work with the car and the transmission lived for almost 2 years.
The major problem is HEAT. The torque converter transforms power into heat whenever you accelerate, and also whenever you decelerate. Even with synthetic trans fluid and a big cooler, I saw temperatures reaching 345 degrees, not too hot for synthetic fluid, but much too hot for the O rings in the transmission.
If you plan to drive your automatic trans vette on a road course I suggest that you leave it in Drive (not overdrive) and just drive the track. You will have to be a little careful comming out of corners (that the car does not do an abrupt downshift), but be smooth and you will be just fine.
:seeya :seeya :seeya :seeya :seeya
Would a tighter torque converter create less heat? I thought the "slipping" of a loose converter created alot of heat. Sounds like the key is a "huge" tranny cooler. I never realized road racing created so much heat and was so hard on the trans fluid. Very interesting. The sessions on the track are usually 20 minutes. If I were to drive the entire 20 minute session non-stop, I would be pretty exhausted. Sounds like it would be pretty hard on the trans fluid too. I usually only last 10 minutes, then take a short break, pick up a passenger, change drivers, then go back out for another 7-8 minutes. That might help the trans temps stay in check. But who wants to baby the car too much. The 100 hp audi can go all day long without a needle moving up past halfway. It doesn't have enough power or weight to really even overpower the brakes in a session. Its just painfully slow though. I would assume a manual trans vette could have this kind of durability too. Auto transmissions sure are nice for all around street/canyon/drag cars, would be nice if you could use one on the road course too.
-Ken
Drop me an email (michael at millerville.cc) we've got a local group of folks that pretty cool.
I'd arrange a trackday, but I've got twins being born in less than two months, one vette is sans-tranny, and both of 'em are on vacation status for some unknown period of time.
BTW, If you're keeping your C4 near stock, it's much easier on your tranny and brakes. I put 30,000 hard miles on the tranny, have know idea what it's service life was like before I bought it, and at 110,000 miles, when I did the rebuild, it wasn't really in that bad shape. (ran great except for a lazy downshift from 2nd to 4th)
Likewise, the brakes never gave me problems...and got much better when I upgraded the pads (Performance Friction Z pads...work great, dust isn't too bad, squeak like mad in stop n go traffic), but when I changed the brake hoses to braided ones, I now have to bleed the brakes halfway through a track day.
Works great, but you have to watch for the WOT downshift to first. This depends on the layout of the track. My club rents a 3/8 mile oval and sets up the cones on it. Took me a little while to figure out when to nail the accelerator out of turn 4 so it didn't downshift on a nasty bump in the track.
I'll find out next year on track events.
