Who has the Fastest C1-C5 Corvette?
Re: Who has the Fastest C1-C5 Corvette? (Daves90)
I didn't think you were being condescending in your post. I thought it was an interesting question. I wrote the slow race car/ fast street car as I was musing and I didn't think it would be picked up on.
Around here the cops are in full force because we have a huge ricer population and they are cracking down. It easy to be at the wrong location at the wrong time, so I've had to build my ride to look and sound like there goes "just an other gray haired old fart driving a Vette re-living his youth". I've managed so far, but it's not easy getting a car to run very fast and appear stock. The gray haired old part was easy. :) BTW all I have left to do is put on my new polished GS wheels and box the exhaust tips.
Re: Who has the Fastest C1-C5 Corvette? (Jim Holbrook)
If I could get my Vette into the low to mid 12's, I'd be happy.
I already don't drive the '74 enough, might as well make it faster!
Jeff
Re: Who has the Fastest C1-C5 Corvette? (Light84vette)
Well........ I'll take ya all on with my mostly stock 84 :jester :jester . I'm pretty sure that accel sticker in my trunk is worth 15-20 hp!!!!:D :D :D
A friend of mine is building an 84 that should do about 9.50:eek: when he finishes it, an no it definately is no longer a crossfire.
Wedge.
:seeya :cheers: :thumbs:
Wedge.
Location: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
1 Post
There's a guy in our club and also one of the "Chicago Wise Guys" who has a '59 vette. Real '59 body, doors, etc but is framed out. Street legal, can run on the road, and has competed in those drive and drag events. You have to drive a 25 mile run and then drag it after cool down without lifting the hood or changing anything. His car has been on the cover of many vette Mags as he owns a body shop and restoration facility. Don't know if this qualifies as a real vette for you but he run's 7.11's in the quarter, maybe even faster.
Hope this helps! :chevy
Re: Who has the Fastest C1-C5 Corvette? (WEDGE)
Wedge.
Wedge.
[Modified by Red84CrossFire, 4:49 PM 11/25/2002]
Hey Wedge and Red84CrossFire, I was thinking that if you changed the CF setup and went with a 4bbl TBI injector, or 2 2bbl TBI injectors that would work even better than the CF and still work with the stock Ecm. The thing is that the CF runs two injectors with two drivers, You splice the main source of the stock ECM and run extra wires to a Scrap ECM which will amplify the impulse to run two more injectors. Then you could run 4 TBI's which would be like a carb, good for a Roots if you put one on top of your engine, or NA. I got the idea from (Joby) which gave some pics and ways of doing this.
As for the fastest, Yeah I think a Corvette that can actually get to the track without the use of a TRAiler to haul it around. Secound I would think that the doors should work, Windows, Also their should be A/C, Radio, Passenger seat, things that are for real, no fake vette. I think that it is eady to get a Car to run down the track that fast, but to make it FAIR , it should be stock appearing, no blower scoops, or chuts.
Re: Who has the Fastest C1-C5 Corvette? (TurboVette)
Just looked at your web page...All I can say is OMG what a car...thats incredible,,can you send me the h/p and tq specs on that thing? :cool: :cool:
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Hope this helps
Re: Who has the Fastest C1-C5 Corvette? (stormy652)
DAng that pretty FAST 7.11's in the quarter, I think this is all out fast, but I'm looking for one that has A/C, Smog, Functional everything, nothing taken out to make it lighter because that would be like just helping it out to become a single purpose Drag Car, not a street sar as well. :D
#33
Got it.. Thank You... IMO that thing is just flat off the chart for way :cool: Im surprised the rearend has hung together...
#34
1 Post
Sort of leaves me out of the running there. I deleted air pump and A/C. Heck, the oder vettes didn't have an air pump and A/C was an option. I can drive my car to the track, I even drive it to work once in a while. Looks bone stock just sitting there until you start it up. It runs 11's.... 10's with "sissy gas". :cheers: :chevy
#36
1 Post
I'll have to get some scanned in. I am a new member as you can tell by my # of posts. I have not had time to build a web page with pics, etc. I'll get some pics and send you a couple. Jpegs most likley. My vette looks bone stock with the hood down. The 3" exhaust and pipes are a clue. I had it in the Chevy/Vettefest two weekends ago in Chicago. Anyway I'll send you a few pics in the next few days.
#37
Re: Who has the Fastest C1-C5 Corvette? (MJT383NO2)
What mods did you have to make in order to get the TH400 in there. Also if your running a TH400 which has a 1:1 gear in 3rd and you have 3.73 rear gears with assuming 25inch tires that would be-3,000rpm at 60mph-Then you would only be at 120mph at 6,000rpm? :confused: Or do you have a overdrive unit?
#38
1 Post
To get the 400 in required a custom tailshaft housing to made. This housing had the exterior bolt pattern and length of an 700R4 so that it bolts right into the stockC4 trans mounts (C-Clamp). The internals (bushings etc.) and the interface to the 400 case (bolt pattern,etc.) where made to match a 400.
This was made of aircraft aluminum by a tool & die friend of mine. As far as the gear ratio and tire diameter you are close. usually run with drag radials on 17" wheels, a bit taller I think than 25", but you are still close at the RPM/MPH figures. My redline is 8100 rpm. So I can do 130 at 6500 rpm with no problem. I have a purpose built, from the ground up race motor. Hope this helps. :chevy
#40
1 Post
As you probably can guess, I didn't build this car for milage on the highway.
with that said, The best I get is about 11 miles per gal. I usually stay at 55-65 hue to the high rev's. I don't take long highway trips. Also it gets a regular diet of 100 octane. This car goes to cruise nights, drag races, shows, Saturday night fun runs looking for vipers, hot stangs, etc. When I go to drag strips more than 50 miles or so away I trailer it. I have been thinking of the Gear vendors overdrive unit however. But for the money, is it really worth it?
I suppose it would help me get to 150 mph. Hmmmm :yesnod:
