TPI Intake Matching Head
Old Apr 10, 2020 | 04:54 PM
87redroadster's Avatar
87redroadster
6th Gear
Default TPI Intake Matching Head
I am building a temporary replacement engine to have the original done completely. The temporary block is a TBI truck engine with roller setup. I am not looking for anything amazing or wild just sound daily top down nice weather driver while the other one is being worked over. I have a question on heads and intake matching. I plan on using the Summit 62cc heads and their only in house TPI roller cam listed @.450/.450. Here is question. Summit has two heads options, all bolts at 90* but perimeter valve covers, or 87-95 center 72* (or 73*) middle bolts but center bolt valve covers. I would like to use my stock 87 center bolt valve covers, becuse I'm a bit picky. Can I use a Camaro/Firebird intake manifold with the current runners, and plenum and no additional fitment problems. Or are there aluminum shims/gromets the adapt my current intake to account for the different angle on,the four inner intake bolts? Or do I need the perimeter bolt heads and 90* four inner intake bolts and buy new valve covers or used 84, 85, 86 covers?
