No Spark - No Start
Old Jun 13, 2020 | 05:09 PM
Myran's Avatar
Myran
7th Gear
Default No Spark - No Start
Good Afternoon, I have a 1984 Cross Fire. I have no spark. I have replaced Cap, Rotor, Coil, Ignition Module & Harness and Pick-Up Coil. The D.U.I. Distributor has less than 4,000 miles on it since new. I have good grounds and 12.9V to distributor. Engine turns over fine; fuel system is working - just no spark at all. Does anyone have any suggestions? Thank you!
Old Jun 14, 2020 | 11:24 AM
GregMartin's Avatar
GregMartin
How are you checking for spark? When you say the DUI is 4000 miles old then you say you have replaced all the parts in the distributor does that mean that you have replaced all the parts in a pretty new DUI distributor? Or does it mean the distributor and associated parts were new 4000 mile ago? When did the car run lasts and did anything else happen to it which might explain the lack of spark?
These are pretty simple systems and if all those parts are new and connected correctly with a 12v supply then there are only two options are either the distributor is not turning or you plugs are so fouled that there is no spark.
I’m leaning towards your distributor not turning. Can you remove the cap and confirm that the rotor turns when you crank the engine.
Old Jun 14, 2020 | 12:22 PM
Myran's Avatar
Myran
7th Gear
Hi Greg,
The distributor was new approx. 6 years ago, but only around 4000 miles now on it. Car is stored in a heated garage and was about 3 months since last running. The ignition parts (cap, rotor, etc.) showed some corrosion/pitting, so I replaced them, then continued with coil, pick-up, etc.
I have tested for spark at #1 cylinder with a tester, then at the distributor.
I have checked and confirmed that the distributor is turning.
Is there a situation when the ECM will stop the spark? Possibly a closed sensor or something?
Old Jun 14, 2020 | 06:15 PM
GregMartin's Avatar
GregMartin
Originally Posted by Myran
Hi Greg,
No the ignition system will work without the ECM but won’t be able to advance past what the module is capable of. Incidentally if you are not getting spark are the fuel injectors pulsing fuel. If yes then your module and associated low voltage stuff is ok and the issue is with your coil or something north of it. If no fuel the it’s related to you module, pickup coil or condenser. Also what does your tach wire and filter look like are the intact and connected up.
Old Jun 14, 2020 | 08:26 PM
Myran's Avatar
Myran
7th Gear
Yes, the Fuel Injectors are working when it is cranking. Tach wire and filter are connected and look good.
I just installed a new Delco coil - I wonder if it is faulty?
Old Jun 14, 2020 | 10:39 PM
GregMartin's Avatar
GregMartin
ok well that’s good. If the injectors are firing then most of it is working. You can measure continuity on the low tension side of the coil but I don’t know what it should be off the top of my head. Also there is a graphite pin in the centre of the cap that connects the high tension side of the coil to the rotor button, maybe check that it’s in place.
Old Jun 15, 2020 | 06:33 AM
Myran's Avatar
Myran
7th Gear
OK, I'll check the coil to be sure the connections are good. Thanks.
Old Jun 15, 2020 | 07:25 AM
GregMartin's Avatar
GregMartin
The primary should measure between about 0.4 and 2 ohms and the high voltage side or secondary should read about 6000 to 15000 ohms. The secondary may be hard to measure with a standard multimeter.
Old Jun 15, 2020 | 04:32 PM
ctmccloskey's Avatar
ctmccloskey
They folks with 1984 Crossfire Corvettes are lucky to have folks like you that can help them out with their unique Corvette!
I am pleased to say that there are some of us with zero Crossfire experience that learn "every time" you help some Corvette owner out and for this I am grateful! That Crossfire seems like a simple enough but the differences are amazing.
Thanks for the education Greg!
Old Jun 15, 2020 | 06:00 PM
GregMartin's Avatar
GregMartin
They are pretty simple really Chris. One of the good things is that you can see the injector spray so that simplifies fault finding. They are a MAP tuned engine which is great for tuning but doesn’t quite have the finesse of a MAF arrangement. I guess that’s why modern engines have both.
Oh and BTW I think you’re one of the “good guys” Chris. You’re always on here giving detailed and considered advise to people without fear or favor. I for one always enjoy reading your responses and I generally learn something especially when you talk about aeroplane engineering.
Old Jun 15, 2020 | 08:07 PM
jseremba's Avatar
jseremba
This is really dumb. Is the battery wire connected to the distributor? Sorry, just thinking.
Old Jun 15, 2020 | 09:05 PM
GregMartin's Avatar
GregMartin
Good question but he stated that he had 12v at the distributor in one of the early posts. Also with no power on the distributor the ECM doesn’t get pulses so doesn’t fire the injectors.
Old Jun 15, 2020 | 09:13 PM
jseremba's Avatar
jseremba
Thank you for the kind response. Some people would be so hateful. But, I know I have cranked and cranked and then doh!! The wire is loose. Thanks again.
Old Jun 16, 2020 | 12:07 AM
GregMartin's Avatar
GregMartin
Yeah absolutely man I have too, and when I was first reading the thread my first thought was I bet it doesn’t have 12v. I’m not into shitcanning people as far as I’m concerned there is no such thing as a stupid question. This forum would be useless if people were to scared to ask questions or suggest answers.
Old Jun 16, 2020 | 12:09 AM
jseremba's Avatar
jseremba
Frankly, if people did a little less hating the whole world would be a whole lot better. Have a great day.
Old Jun 16, 2020 | 12:13 AM
GregMartin's Avatar
GregMartin
You too man
To No Spark - No Start
