Cant find an Alternator with a Correct bolt center
#61
Yeah you can rebuild the alternator and replace the regulator and the diodes and probably the bearings. Normally you would buy a refurbished unit and exchange your old one. In this case the OP in a his thread was asking about upgrading the alternator with a CS 144 which is a good option for an 84.
#62
#63
That’s right he’s not. This was Bills thread about replacing his alternator And mike has added his question. However the fact still remains that if you are going to open up an alternator you should replace the diodes and bearings as well as the regulator.
#64
Agree to disagree here it seems.
#65
For me its if I'm there I might as well I suppose. I bought a whole rebuild kit including bearings and regulator for like 23$. Cheap enough and easy to do but if it is fairly new I don't see the need either... with my luck however the thing would cone apart shortly after... but thats my luck.
#67
#68
#72
This post is why I assumed English wasn’t your first language. It’s not a criticism being multilingual is something to be proud of. But if that’s not so I guess it’s just a case of word soup.
#73
