I am an Idiot :)
Old Dec 6, 2002 | 05:11 AM
keekster's Avatar
keekster
Default I am an Idiot :)
I took the Intake Manifold off the LT1 so long ago I forgot what holes the studs go in and what holes the bolts go in. Can someone help out
Old Dec 6, 2002 | 08:29 AM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: I am an Idiot :) (keekster)
im sure if you look in a service manual, like those haynes manuals, you will hind enough pictures to figure it out, or go to the dealer and look on their computer in the parts department :yesnod:
Old Dec 6, 2002 | 09:25 AM
ittlfly's Avatar
ittlfly
Chris,
My wife is out with the vette (and my Helms are in the back) but if no one jumps in before she gets back, i'll take a look.
Old Dec 6, 2002 | 09:47 AM
GlockLT4's Avatar
GlockLT4
Default Re: I am an Idiot :) (ittlfly)
Sorry, I'm at work and I don't have an LT1 anymore. The LT4's might use bolts in different places possibly, so I wouldn't want to give ya anything wrong.
Old Dec 6, 2002 | 12:00 PM
VetBoy89's Avatar
VetBoy89
Here is the pic from a 96 Camaro LT1, I think they are the same aren't they? I'm not positive so hopefully someone else can confirm, but here is the pic...
Hope it helps. :cheers:
[Modified by VetBoy89, 9:02 AM 12/6/2002]
Old Dec 6, 2002 | 05:01 PM
keekster's Avatar
keekster
Looks like the camaro has a couple more stud bolts than the vette I only have 3 thank you though :)
Old Dec 6, 2002 | 06:43 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
I sent you an email with the page out of the service manual on the location for the studs. It should be the second to last bolt. Hope this helps.
Leo. :seeya
Old Dec 7, 2002 | 01:09 AM
keekster's Avatar
keekster
Default Re: I am an Idiot :) (GS487)
Thank you Do you have the page for the other side
Old Dec 7, 2002 | 06:48 AM
04Z16's Avatar
04Z16
Chris,
The service manual does not show a shot for that side that I can find. Everything only shows the drivers side. I just looked at the Right Hand side on my car. On the LT4 which matched the drivers side in the book, the passenger side has two studs which should be the same for the LT1 and are located the second bolt hole from the front and the last bolt hole. Hope this helps. I scanned the other half the manual page and listed where the studs are for you also. hope this will help.
Leo
:seeya
Old Dec 7, 2002 | 04:04 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Always use my digital camara....so as to show before...take down...this has really helped me. Guess to each his own.
:crazy:
To I am an Idiot :)
