C4 vantilators wor all the time
Old Dec 10, 2020 | 02:30 PM
Marcin Swiatek's Avatar
Marcin Swiatek
6th Gear
Default C4 vantilators wor all the time
Hi
In my vette c4 1990 ventilators work all the time. Just after engine starts, they start as well.
Second thing is that when is cold outside, it engine starts quite hard.
I think those two things are connected with each other.
If anyone has some suggestions, I will be appreciated for them.
Best regards
Old Dec 10, 2020 | 03:01 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Originally Posted by Marcin Swiatek
Hi
Best regards
Is there a question?
Old Dec 10, 2020 | 03:15 PM
Deepa's Avatar
Deepa
Is the check engine light on? Are you running the ac?
the fans shouldn’t run all of the time.
Old Dec 10, 2020 | 03:59 PM
Marcin Swiatek
6th Gear
AC is off. Check does not flash
cv67's Avatar
cv67
St. Jude Donor '05
Fan for the ac and heat or engine cooling fan?
Old Dec 10, 2020 | 05:26 PM
Deepa's Avatar
Deepa
Does the check engine light come on as you’re starting the car? Is there a chance the bulb is burned out?
the later tpis are known for injectors failing. Can you ohm them out to see if the coils are good?
have you checked basics like fuel pressure?
1990s had two fans right next to each other.
Old Dec 11, 2020 | 01:45 PM
85WHITEZ51's Avatar
85WHITEZ51
Check your coolant temp sensors, should be two of them (at least their is on my 85). One is for the gauge and one is for the ECU. If the fans are on all the time AND it is hard to start only when cold it sounds like the sensor that talks to the ECU may be bad and is telling the car it is hotter than it actually is thus bypassing the cold start routine.
Old Dec 11, 2020 | 06:01 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
if you are talking about your HVAC (blower motor that blows heat or ac through vents) then your blower motor resistor is most likely culprit. When they fail, they fail on full blast. This is so in case of emergency you are not starving for defog front windshield. It is located on top of blower box, under hood, passenger side, beside the #8 cyl.
Old Jan 10, 2021 | 10:31 AM
fredk's Avatar
fredk
By the way my mother was a Flemish war bride.
To C4 vantilators wor all the time
