1992 Wheel Fitment
Old Jan 11, 2021 | 02:32 PM
EmilyTheCorvette's Avatar
EmilyTheCorvette
Cruising
Default 1992 Wheel Fitment
Hey guys! I'm currently in the market for some aftermarket wheels for my 1992 LT1 C4 Coupe, but I was wondering what fitment I would need to get them flush if I bought them the same size as stock wheels (17" x 9.5"). Think you guys could help me out?
Old Jan 11, 2021 | 10:06 PM
Kevova's Avatar
Kevova
Factory off set is 56mm. 50mm ( gen 4 f body ) will work.
Old Jan 12, 2021 | 09:44 AM
MatthewMiller's Avatar
MatthewMiller
When you say "flush," I assume you mean you want to put them out even with the outside fender edges. On any 88-96 Corvette, that means you need 4" of "frontspacing," which is the amount of rim width that extends out from the hub mounting surface. It's the opposite of backspacing. With a 9.5" wheel, 32mm offset will get you that flush fit with a 275-width tire. Be aware that this will place added loads on the wheel bearings and increase scrub radius, about the same amount as the 84-87 Corvettes had. I don't know how much this really impacts bearing life. It will add a bit of tramlining and other steering forces. It won't be anything terminal, but it will be different than the "zero scrub" later C4 geometry.
Old Jan 12, 2021 | 11:00 AM
WVZR-1's Avatar
WVZR-1
I believe the only way for the OP to calculate offset required for his desired placement is the 'trusted' string drop and a trusted measuring device! Only way!
He's the 'only guy' that knows where he'd like it and knows what he means by 'FLUSH'! I ain't going to guess/speculate the OP's desires.
Old Jan 13, 2021 | 04:11 PM
EmilyTheCorvette
Cruising
Short sweet and too the point, I love it. 😊
Old Jan 13, 2021 | 04:13 PM
EmilyTheCorvette
Cruising
I appreciate the insight man! And you were correct in my assumption on flush, outside of wheels even with the outside of the fenders. In my opinion it look sleek af.
Old Jan 13, 2021 | 04:14 PM
EmilyTheCorvette
Cruising
I appreciate the concern man, and dont worry, I would never do that without a double check lol. I was just looking for some extra insight.
To 1992 Wheel Fitment
