1985 Engine Mods Recommendations
Old Feb 3, 2021 | 12:26 AM
Auto87's Avatar
Auto87
8th Gear
Default 1985 Engine Mods Recommendations
Hello all,
My TPI has 110k miles and no modifications outside of a Cat delete and a muffler delete. Tranny was rebuilt a few years ago. I want this engine to achieve the ideal 1 hp per cubic inch, but if the block can handle more, that would be better. How much parts cost isn't a problem for me. Any ideas/recommendations would be appreciated.
Old Feb 3, 2021 | 07:55 AM
vader86's Avatar
vader86
Easiest way to just achieve the goal of 350bhp is headers, then switch to Miniram, which will get you to the 300hp range, then have heads/cam.
A later L98 might be able to do it with just cam, but 85 has the '624 heads which are not all that good, and won't quite flow enough to get there. So you must decide whether you intend to go beyond your goal or just want enough head to flow it. If you intend to stay as a 350ci, I'd go with AFR 190s. Add in a reasonable cam, maybe 218/228@050 and you probably get there. Remember 85 is flat tappet, not a roller cam (though you can convert). Add 1.6RR and a custom tune on a dyno and you should be there or above.
Old Feb 3, 2021 | 08:03 AM
aklim's Avatar
aklim
Rebuilt to what? Stock level? It isn't that good for beating on with more power. I shredded it after Linfenfelter put a 383 in it. His last words to me were "It's got about a year.". Made it 9 months with no beating.
In that case, rebuilt trans, D44 rear end, better intakes and headers and a 383 with a custom tune should net you well out of your power requests.
Old Feb 3, 2021 | 08:18 AM
Aardwolf's Avatar
Aardwolf
Are you doing the work and tune yourself? There are some inexpensive ways like later year heads etc but to many mods will need a tune or aftermarket efi controller. For that goal I think you could just do heads and intake. Have your eye on any?
Old Feb 3, 2021 | 09:08 AM
aklim's Avatar
aklim
I'd pass on tuning since it is a lot of work and a "One Off" but I'd definitely think headers. They made quite a bit of difference when I started to modify my L98. Intakes made some difference but the headers added more. Way better after the tune if you want to believe the wife's subjective opinion.
Old Feb 3, 2021 | 09:33 PM
TrailerPark Hero's Avatar
TrailerPark Hero
I have a Holley sniper on my 85 along with cam , edelbrock carb intake , exhaust , ect..... . You can play with tuning as little or as much as you feel like . I don’t know the HP but it’s definitely a lot quicker .
Old Feb 3, 2021 | 10:14 PM
aklim's Avatar
aklim
Why would you have to play with the tuning? If it is self tuning, it should tune itself after you set the basic parameters. If it is not self tuning and it is set right and you don't make changes, it should not need to be worked on. Not sure I see.
Old Feb 3, 2021 | 10:28 PM
TrailerPark Hero
Because it’s fun to play with . It set my WOT to 12.8 runs perfect. But I read an article about how L98 heads do really good at 13.0 . So I changed it slightly and it made no noticeable difference. It easy enough to change while sitting at a red light
Old Feb 3, 2021 | 10:36 PM
aklim's Avatar
aklim
OK. I was trying to see if self tuning is going to be as good as a professional tuner with a dyno
Old Feb 3, 2021 | 11:25 PM
TrailerPark Hero
whats the big advantage in switching an 85 ecm out for say a 1990 ?
Old Feb 4, 2021 | 07:54 AM
Mixednuttz's Avatar
Mixednuttz
2023 Corvette of the Year Finalist - Modified
2022 C4 of the Year Winner - Modified
Finalist 2020 C4 of the Year - Modified
Because the system is not "self tuning". It only tunes the fuel poundage to meet the air fuel ratio in that cell of the fuel map. The same pretty much for the ignition timing: it only sets the timing to what it is demanded at that spot in the timing map. You have to tell it what those values are. The system does have some generic fuel and timing files that should get you started but the tune would likely need to be tweaked some to maximize the power and make the engine run as well as possible.
Old Feb 4, 2021 | 12:35 PM
TrailerPark Hero
Originally Posted by Mixednuttz
Because the system is not "self tuning". It only tunes the fuel poundage to meet the air fuel ratio in that cell of the fuel map. The same pretty much for the ignition timing: it only sets the timing to what it is demanded at that spot in the timing map. You have to tell it what those values are. The system does have some generic fuel and timing files that should get you started but the tune would likely need to be tweaked some to maximize the power and make the engine runs as well as possible.
It’s pretty cool that it can control timing if you want it to but not necessary. But it’s also capable of controlling Nitrous and can handle boost up to 20psi . Gives me options for when I swap to a 6.0 ls . I’m not saying it’s the best setup and everyone should run it . All I’m saying is it’s an option for someone wanting to get more power from a stock l98
Old Feb 4, 2021 | 06:12 PM
Mixednuttz's Avatar
Mixednuttz
I wasn't knocking the system. Just explaining how the "self tuning" works. (Holley would be doing themselves a favor by discontinuing using that term.) I have the HP in my turbocharged 85 and will be upgrading to the Dominator only because I need more IOs.
Old Feb 4, 2021 | 09:46 PM
aklim's Avatar
aklim
I thought 85 had issues with a scanner? I thought it also had better tuning abilities? Not sure. I never found the motivation to get into tuning. Looking back at the receipts, it was about more than10 years between tuning. The other time was for a dyno tune and the latest time was to get some refinements into the system. More of tuning out some of the harshness that I noticed over the years.
Not sure why since 90 was Speed Density and is less adaptable than MAF when you do small mods. What would you say is the advantage?
Old Feb 4, 2021 | 10:01 PM
aklim's Avatar
aklim
That's disappointing.
To 1985 Engine Mods Recommendations
