LT1 Intake conversion, anyone tried it?
Old Dec 12, 2002 | 01:10 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default LT1 Intake conversion, anyone tried it?
I was wondering if anyone here has done the TPI to LT1 intake manifold conversion from www.lt1intake.com
It looks like it would be a nice addition to the L98 i'm rebuilding. I'd like your input... :cheers:
Old Dec 12, 2002 | 02:12 PM
gtsyellow's Avatar
gtsyellow
Default Re: LT1 Intake conversion, anyone tried it? (CarAteMyMoney)
look in the parts forsale section, there's a GREAT deal on one
Old Dec 12, 2002 | 02:57 PM
jmr302's Avatar
jmr302
Working on that swap now. It takes a fair amount of work but it's much cheaper than a Miniram. I bought my intake on Ebay. I thought John@lt1intake.com had converted but it was a Bubba-rigged job instead. I believe the two intakes in the For Sale forum are both John's work and I wouldn't shy away from either one.
Old Dec 12, 2002 | 03:16 PM
gtsyellow's Avatar
gtsyellow
Default Re: LT1 Intake conversion, anyone tried it? (jmr302)
how can you jimmy rig a hole for the distributor? it's either drilled right or it isn't? the fuel rails have to be custom but nice AN fittings were used. i haven't seen or used any of the products but i don't see how you could really screw one up unless you drilled the hole wrong.
Old Dec 12, 2002 | 05:19 PM
jmr302's Avatar
jmr302
Default Re: LT1 Intake conversion, anyone tried it? (gtsyellow)
That doesn't make sense-->"how can you jimmy rig a hole for the distributor? it's either drilled right or it isn't?"
It's extremely easy to mess things up when you have the wrong tools and don't know what you're doing.
The hack that converted my manifold drilled the rear coolant crossovers too close to the edge of the manifold. All of the NPT threads are lose from over tightening. This manifold was modified with a grinder, not a mill. It looks nasty and sloppy. The intake mounting holes are all egg shaped and much larger than they need to be. There is an excessive amount of JB Weld in several areas. The hole for the distributor appears to be the only clean operation performed. I haven't verified if it was located properly.
Once again, John at LT1intake.com does very good work and I'd buy one if it came out of there. If it didn't I'd ask to see detailed pics or I wouldn't pay much for it.
Old Dec 12, 2002 | 05:53 PM
gtsyellow's Avatar
gtsyellow
makes ya wanna look for a used miniram doesn't it :jester i think the one in the FS section was from john.
Old Dec 12, 2002 | 06:54 PM
Speedracer176's Avatar
Speedracer176
anyone have pics (poss. detailed pictures) of the inside of a LT1 intake?
To LT1 Intake conversion, anyone tried it?
