ZZ4...Too Much Cam?
Old Dec 12, 2002 | 02:30 PM
CAJUN C4's Avatar
CAJUN C4
Default ZZ4...Too Much Cam?
Anyone running a ZZ4 cam in an Automatic with stock converter and 3:07's?
Let me know what you think?
Old Dec 12, 2002 | 03:08 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: ZZ4...Too Much Cam? (CAJUN C4)
I've got one on the shelf waiting to go in.... same setup: '90 automatic with 3.07's.... From what I've seen it's not too much bigger than the stock '90 cam as far as duration. Lift is quite a bit more though. Duration is larger than '86-'89 cams though.
Old Dec 12, 2002 | 03:11 PM
gtsyellow's Avatar
gtsyellow
Default Re: ZZ4...Too Much Cam? (Marcho Polo)
it's larger than any L98 cam in lift and duration. might slip by alright on the stock chip even. i think it would work great in your app. still waiting for polo to install the one i sold him & give us some feedback :)
Old Dec 12, 2002 | 04:12 PM
CNTDRV55's Avatar
CNTDRV55
I've got one on the shelf waiting to go in.... same setup: '90 automatic with 3.07's.....
You putting it in the '90??? Isn't this a pre-emissions engine? :confused:
[Modified by cgtarga1, 3:12 PM 12/12/2002]
Old Dec 12, 2002 | 04:19 PM
CAJUN C4's Avatar
CAJUN C4
Default Re: ZZ4...Too Much Cam? (cgtarga1)
Going in a 86' TPI
Old Dec 12, 2002 | 05:52 PM
gtsyellow's Avatar
gtsyellow
won't go in a 86 tpi without some modification like retrofit lifters and stronger springs. that goes for the later cars also, you need something like the LT4 spring, the zz4 cam is a hyd. roller, the 86 is flat tappet.
Old Dec 12, 2002 | 07:11 PM
tommelton's Avatar
tommelton
Default Re: ZZ4...Too Much Cam? (gtsyellow)
I am (was) running a complete ZZ4 in my 86 auto coupe. No problems as far as vacuum or transmission. I had the 3.07 ratio also.
I am now running a ZF6 with 3.45 gears though, but I wanted a 6 speed... :)
Tom Melton
82 CE
86 Z51 Coupe
To ZZ4...Too Much Cam?
