Disconnect Timing Ignition On?!
Old Jun 23, 2021 | 05:45 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Default Disconnect Timing Ignition On?!
Howdy all. Resetting my minimum idle after engine rebuild, '87 L98. FSM instructions includes the following:
4. Turn ~~ON" ignition, do not start engine. Wait at least 30 seconds.
5. With ignition ~~ON", disconnect lAC electrical connector.
!Important! Disconnect the distributor set-timing connector.
6. Start engine and allow to go Closed Loop".
Is it safe to disconnect the timing connector with ignition on, engine stopped? Double checking before having to get another ECM. Or worse.
Old Jun 23, 2021 | 06:21 PM
Mrvettenick's Avatar
Mrvettenick
No, it shouldn't be an issue.
Old Jun 24, 2021 | 10:51 AM
kael's Avatar
kael
Did as instructed, no issues.
To Disconnect Timing Ignition On?!
