Had to remove airbag to repair horn. When horn was repaired reinstalled the airbag now the airbag light will not go out.
can I clear this without a tool ?
tried disconnecting battery for a while did not have any effect.
thanks for any help !
Battery disconnect will NOT.
If you have the FSM Book 1 9J-A-2 for reading and 'clearing' codes. You do want to check for codes before just doing the 'clear'. Many struggle with the 'timing' required for the procedure. Some have used/tried switches and such.
