Using heat on a rusted joint/hinge
I have a 1000 degree heat gun and used it to heat the joint but I don't know if I'm doing it right. Do I heat cycle it to break up the rust? Heat it and persuade it with a hammer? How is this done?
Here's the trouble spot:
Thanks!
That something is.....(get ready for it folks). I've said it many-a-time and I guess it needs to be said again:
HEAT
Heat it up...get it HOT. Don't use a hair drier...HEAT IT. Get a torch and heat the wee out of it, then work it back and forth...it'll free right up. Not in two days, not in a "week of soaking"....it'll free up RIGHT NOW!
Don't dick around w/o potions of lore and Mom passed down. Get a torch, heat thing up and get it moving. When it cools, lubricate it then, with the potion of you liking.
The thing is, I do this **** for a living...and I get paid salary, not hourly. So the faster I get this **** done, the sooner I get to go home*, or do other things that I'd rather be doing. Therefore, If I can avoid dicking around with Kroil, PB, WD, Liquid wrench, ATF, Candle wax, Dog ****...whatever potion is your flavor...if I can avoid wasting hours, days, or a week letting it "soak", you can bet your *** that I'm going to avoid that. I'm going to bust out the torch, give'r hell and have it loose in minutes. Other methods can work...but heat works, RIGHT NOW! Then I can finish the job and move on to other responsibilities or fun.
When I give advice on here, I want to give the BEST advice. Yeah, I know 10 different ways to get any problem handled. I could share all the slow and difficult ways to get things done, because I did 'em all back when I was an inexperienced dumbass and fought with things like rust. But why would we do that? If you have the resources (a torch, in this case) to do it the fast/easy way...right? Do it that way.
*In fact, just yesterday, I was helping my guys at work, by doing brakes on a truck. Truck had 3 calipers with frozen sliding pins. Frozen enough that neither a 3' breaker bar, nor a 1/2 impact would budge them. The thread of the pins weren't frozen...the pin was frozen in the bore of the caliper. So...I COULD have put some potion on it, waited for hours (days?) and then tried again with hopes and dreams. But I didn't. I fired up the torch, heated the pin bores up, and then zipped 'em out with the impact. Boom. Then I could finish the job and go home.
