85 injector/wire covers
Old Jan 11, 2023 | 08:19 PM
johnfin's Avatar
johnfin
Default 85 injector/wire covers
Were these one year covers held on with screws or bolts?
Old Jan 11, 2023 | 08:55 PM
s carter's Avatar
s carter
Are you talking about these, if memory serves me they are retained 7mm head screws on the Right as part of an aluminum tube bolted to vc that goes from throttle body to valve cover. On Left an aluminum bracket bolted to top valve cover bolts again. 7mm head screws
This style I believe where Iron head exclusive, you can also find them on Camaro and firebird
https://www.ebay.com/itm/13430458635...EAAOSwuctjXA1k
Old Jan 12, 2023 | 07:27 AM
johnfin's Avatar
johnfin
Yes those are the covers. When you say screws do you mean sheet metal screws or machine screws. 7mm head? What type of head? If its similar to any other bolts near the intake I might be able to get an example of something I already have. I know it sound petty but I dont want to screw up the threads on the aluminum piping,
Old Jan 12, 2023 | 08:08 AM
s carter's Avatar
s carter
the 7mm are the standard black trim screws you see all over the car. as for what they screw into are tabs that are part of a pipe that runs on top of VC between Plenum using top Valve cover bolts(right side/Passenger)
Left side is a stamped aluminum Tube/bracket with the tabs for cover and maybe a couple of loom retainers
Left side tube
https://www.bing.com/images/search?v...t=0&ajaxserp=0
photo 2
Right side
https://www.ebay.com/itm/30458339459...Bk9SR5Kq2-K0YQ
Old Jan 12, 2023 | 09:10 AM
johnfin's Avatar
johnfin
Default screws
Like these?
Old Jan 12, 2023 | 09:15 AM
s carter's Avatar
s carter
Originally Posted by johnfin
like these?
yes
DID you see the photos I added to earlier post
To 85 injector/wire covers
