1990 A/C Resurrection
There's a sticker on the fan shroud indicating it was converted to R134a at some point in the past, but there's no information about how much of a charge it was given or how much oil was put in, what kind, etc. I'm going to take a crack at sealing up the system, pulling a vacuum for a while, then charging it up, but I have the following questions:
1. I managed to pull the schrader valve core out of the high-side port, but cannot for the life of me find a matching valve. Anyone know what the size or part number would be? Parts manual from GM indicates it's part of the line. Since the threads on it are all chewed up, I might just purchase a new reproduction line from Zip Corvette anyway.
2. I'm guessing I should change the accumulator/dryer while I'm doing this, but that will remove basically all the oil in the system. Anyone know what the recommended oil for a converted system is? Would it be Ester oil, or would I switch to PAG? Anyting I should/need to do to purge any old oil out of there?
3. Anyone know the system charge amount for R134a? I could look up the original capacity for R12 in the FSM, but I don't know if that'd be the same for R134.
Thanks in advance for any insight you guys could shed (and/or any gotchas to watch out for).
And I appreciate that you're trying to keep me out of trouble with this, but I think lots of folks here take on tasks that have some risk and require climbing a bit of a learning curve if you want to do it yourself correctly. That's what I'm trying to do here. If I assumed I already knew everything, I wouldn't be asking for help.
If you've already found this to be the source of the leak, why not just replace the fill valve instead of the whole line? It's a helluva lot easier and cheaper, it just screws out and you replace it with a new one. I did this and got a new valve from Autozone for $3.89, evacuated and refilled the system, and problem solved. And that was 2 years ago, no leaks since.
OK, so I've continued down my path of investigation into the specifics of this A/C system and here's what I've found:
So it looks like there's a total of 8oz. of oil in the system along with 2 1/4 lbs. of R12 originally. Online rule-of-thumb sources seem to suggest that the correct charge of R134a would be (Original Charge in lbs x 0.9) - 1/4 lb. Using that formula here would give (2.25 * 0.9) - 0.25 = ~1.78lbs or 28.4oz. This works out to almost exactly the 80% number that arbee recommended (1.75lbs/2.25lbs), but is pretty far off from the 14.6oz that Dredgeguy recommended. Anyone else have any insight as to which is closer to correct?
Also, there's a table of oil capacities to add depending on what component is replaced:
So it looks like arbee is correct again on this one to a fair extent. I was wrong in thinking "most" of the oil would be lost if the accumulator is changed, but it does look like 3.5oz or about 43% of it will need to be replaced. A few questions on this front as well: The R134a conversion kits on Zip Corvette look like they come with Ester oil. I know the R134a system in my 2002 truck used PAG oil. Is Ester oil the correct choice? Elsewhere in the FSM it calls out "525 viscosity" refrigerant oil. Every reference I can find to this viscosity is for R12 only. Is there a correct and particular viscosity Ester oil that should be used here? And it definitely should be PAG, correct? Finally, there's a note here that says the accumulator should basically ONLY be replaced if it's damaged. I've seen numerous other forums and articles (admittedly not related to the C4 Corvette) that suggest that if a system has been depressurized and/or open to the atmosphere for a long time it's good practice to replace the accumulator. It's only a $20 part, so if there's any value in replacing it while I've got things torn apart, I'm inclined to just do it.
The last important piece of the puzzle I'm working on now is what to expect during/after charging to know whether I've got things working right. Here's the performance table from the original FSM:
My question is: Is there an established way to convert this performance table into what I'd expect with R134a? Do I just use these values as-is (seems unlikely).
Again, thanks in advance for chiming in with some details in an effort to help me maximize my odds of succes (and perhaps minimize the odds that I end up buying a new compressor in a month.
EDIT: One more question: Assuming I pull a vacuum on the system and perform the vacuum hold test, I'm guessing I should need to purge ONLY the charge line from the new can of R134a since the high and low-side lines will still be at nearly full vacuum. Is this assumption correct?
Sorry about the confusion.
We replaced the high-side line, accumulator/dryer, orifice tube, and all the O-Rings at every connection we broke (most of them except the upper evaporator connection and the back of the compressor. Dumped the requisite 3.5oz of Ester oil into the new accumulator before installing it.
Hooked up the gauges and vacuum pump and pulled a vacuum for just over an hour. Then closed off the manifold connections and let it sit for about an hour and a half - no loss of vacuum so I'm thinking we were in good shape.
Purged the charge line and started up the car/compressor and pumped in most of the first can of R134a. Eventually the A/C/ controller tripped out from fast cycling. Rather than jumper the pressure cycling connector, I just had my son disconnect/reconnect the battery. Did this twice. By the time we were loading in the second 12oz can of refrigerant, it had enough low-side pressure to stay on. I didn't do things completely by weight, but we were well into the third can of refrigerant when the pressures got to where I decided we were good to go. Probably around 30oz of R134a total.
Was around 88 degrees with high humidity. Low-side pressure hung steady at about 36 psi.
High side pressure stabilized at around 265psi.
After we were done and shut the car off, static pressure stabilized at a bit above 80psi - suggesting maybe could stand to have a bit more charge. At any rate, the system blew nice cold air and all seemed to be working well during subsequent test drives.
Now to the bad news: I strongly suspect this compressor may not be long for this world. When we were removing the old orifice tube, we found the screen was PACKED with crud:
I've seen folks in other car forums refer to this buildup as "black death" and suggest it was from running the system with moisture in it. I guess we will see what happens over time.
Any chance this level of debris buildup is just typical for a 30 year old system and not an indicator that something's on it's way out?
In any case, after a bunch of hand-wringing and information gathering, we were at least successfully able to get the system back up and running. I'll let folks here know if the crud buildup means the compressor meets an untimely death in the near future.
