88 passenger window new regulator goes up but not down help!!
Thanks for letting me join! Just put new passenger side window regulator goes up but not down. I think my old regulator was good but got new one any help I have power to the motor
Sometimes the switch gets gummed up with junk or spilled beverage especially the years with the switch in center console, so here's a little trick I learned way back, Don't rock the switch back and forth with fingertips. Try it with a push down and rock you would be amazed how many times a customer would roll in with a stuck window and it would work, in the end switch needed a cleaning or replacement if truly killed
Window
You can buy the switches st o’Reilly’s. It’s in gheir computer, they just don’t know it.
it is used on a few GM cars back in the 80’s so they should be able to find it, but msy not be called a corvette window switch. I bought a box of four.
switches were $5 each
