Need help please vats
Old May 13, 2026 | 06:35 PM
Mickeyv1's Avatar
Mickeyv1
3rd Gear
Default Need help please vats
I just bought a base 1990 with no key. I replaced key ignition. Bought resistors to bypass vats. The issue I am having is the 2 wires on harness side going to ccm/bcm for vats sometimes shows resistance.
The real issue is I can bypass with a resistor and when I use multi meter it shows 0 when I remove resistor gives me proper reading. Why would it go to 0 when I install on 2 wires for vats bypass?
Old May 14, 2026 | 02:44 PM
Tunedperformancedotorg's Avatar
Supporting Vendor
2 other methods of overcoming the vats , timershop hz module or have the prom tuned with vats delete.
Old May 14, 2026 | 02:47 PM
Supporting Vendor
To wire in a hz module painless or timer shop hook to ecm B6
Old May 14, 2026 | 02:50 PM
Supporting Vendor
https://timers.shop/GM-VATS-Bypass-M...-LT1_p_33.html
Old May 14, 2026 | 03:23 PM
IHBD's Avatar
IHBD
Pro Mechanic
Old May 14, 2026 | 09:37 PM
Mickeyv1's Avatar
Mickeyv1
3rd Gear
Default Thank you
Thank you guys. I ordered the timers 30/50 vaya bypass. Just need to figure out how to bypass the starter relay.
I appreciate the information
Old May 14, 2026 | 09:46 PM
Supporting Vendor
I think the starter enable relays tucked under the driver side dash. It might be a large gauge green to large gauge yellow you need to jumper.
Old May 14, 2026 | 10:54 PM
Mickeyv1's Avatar
Mickeyv1
3rd Gear
Default Relay
I also saw big yellow to big yellow and black
Im
going to try yellow to the green
i see the 2 relays most people say closest to steering but in my case the further one is the one with big gauge yellow wire.
thank you for info
Old May 15, 2026 | 12:44 AM
IHBD's Avatar
IHBD
Pro Mechanic
Old May 15, 2026 | 09:58 AM
Supporting Vendor
https://www.corvetteforum.com/forums...ble-relay.html
To Need help please vats
