C4 new stainless steel braided lines
I have done brake lines on C3's before, but the C4's have a hole in the caliper bolt that should line up with the hose. I saw the "R" on the bolt that lines up with the hole in the caliper hose. How do you know if everything is lined up for maximum brake fluid pressure? That's a small hole.
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: C4 new stainless steel braided lines (HAD2HAV2)
:cheers: I think you are reading more into the situation than is warranted. :D
Just be sure you use the right hoses on the right(correct) wheel and install new copper washers.
I changed mine several years ago and screwed up by installing the wrong hose on the wrong wheel!
Otherwise, don't worry about it!!
:steering: [ I love that Lil Guy! ]
