Heater core done, it was pretty easy.
This is good news, no matter how stale. I haven't had to do a core swap on either of my C4s yet, but was somewhat dreading the arrival of that day.
A very belated "Thanks!" to the OP.
Live well,
SJW
Live well,
SJW
This maybe a old thread but one that is just as relevant today as it was back then. This will be great news for anyone facing a core replacement. Don't know if this is somewhere as a sticky but if not it should be.
Fastguy is still around, he's just working on C5 heater cores now.....WW
That article scared the beejesus out of me. I felt like I was flushing my cooling system with a gun to my head. I feel much better now.
No doubt. It took a while on my 94 .Not hard just time consuming. One more thing , the factory core seems like a more quality piece than auto zone/ oriellys .I took it back and found a factory piece.
#33
95 C4 Heater core replacement
Do you have any idea if the 95 Heater Core replacement procedure is the same as you have described here? Sure be nice to be able to do it without pulling the dash cover.
#36
C$ Heater Core Replacement
I replaced mine a few weeks ago. I have a 31 page PDF document with photographs that show what you will need to do. If you want a copy send a request to wccautomation@aol.com.
#37
Location: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
#38
#39
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
If you follow the generalized steps outlined in POST#1 of this thread, you'll step right through this job. I used those steps to do my 87's last week and it's exponentially simpler than the hoops I've read that others have jumped through to get this job done.
I will add some additional info to the OP's instructions to make things a little easier:
1. If you have C68 (like I do) you will need to remove the blend door motor. To set it up for re-installation, turn the key on, set the heat to full hot, then turn the key off and unhook your battery (-) terminal--this will set the blend motor movement to the rearward most (hottest) position, which is where it needs to be set upon reassembly for correct operation as per the FSM.
2. You need to drop the hush panel on the driver side to facilitate removal of the small tubular heater duct that comes out of the case and hooks to both sides. There are 3 screws that hold the tube in---2 in the case, and one into the dash frame on the driver side...this duct must come out to allow for removal of the rear heater core case half.
3. Have a mirror handy. It makes removal of the top 2 screws of the heater core case much easier. The outermost top screw is partially visible if you contort you head just so (you make a face kinda like this ). The screw above the blend door motor is out of sight, and you need the mirror for that one.
4. There are 3 screws that hold the heater core to the firewall side of the case, 2 on the bottom holding the strap, one (hidden) on the top directly in the middle holding a V shaped retainer...again, use the mirror to locate that top retainer screw.
Take your time, work methodically, and although not the most pleasant job in the world, it should go smoothly.
#40
I get this when I send email to wccautomation@aol.com
This is an automatically generated Delivery Status Notification.
Delivery to the following recipients failed.
