ECM plug to D/C for timing
Old Apr 10, 2003 | 04:24 PM
BIG K's Avatar
BIG K
Default ECM plug to D/C for timing
Where's the ECM plug that you diconnect to time? On mine it's suppost to be tan and black in color.
Also I havn't used my timing light in a "few years" and it's not working. I don't think that I've used it a dozen times. It's a Craftsman.
Is there anything that I can do to get it working again or to check?
The timing light has a advance on it. Isn't this so that you don't have to disconnect the ECM?
Thanks! :thumbs:
Old Apr 10, 2003 | 04:37 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: ECM plug to D/C for timing (BIG K)
ON mine, it is a single connector that is black and it isREAL close to the Brake Booster. Sorry...I am not sure about your questions on the timing light...I just went and bought a new one for $29.99 and it works fine.
Old Apr 10, 2003 | 04:57 PM
needanother1's Avatar
needanother1
Default Re: ECM plug to D/C for timing (Bruthish)
You still need to disconnect the EST bypass wire, regardless of your timing light. It should be a single wire connector that comes out of the big engine harness near the brake booster. On mine it's near the bracket that holds the wiring harness to the firewall, just above the #7 exhaust.
Jason
Old Apr 10, 2003 | 07:44 PM
BIG K's Avatar
BIG K
Default Re: ECM plug to D/C for timing (needanother1)
Thanks man. I'm going to go take a look see again. The sticker on the radiator made it sound like the wire went to the distribitor.
Old Apr 11, 2003 | 01:25 PM
HighHopes85's Avatar
HighHopes85
Err. it does...it is just that the connector is by the power booster because it's a little more convenient to get to. Hell, F@rd puts their SPOUT (spark output) connectors on the inner fenderwells, kinda like where they occasionally put their EST modules.
You disconnect the wire and then timing is all controlled by the EST module. At this point, advance is fixed via the module. There is some built in advance with the module, but you're not gonna want to write home about it. At ~400RPM, your ignition setup usually switches from this advance to ECM advance. If you have the bypass wire disconnected, you won't have the ECM controlling the advance. It's GMs way of KISS.
If your timing light has a dial on it, it's probably a 'dial-back' timing light. Kinda handy when you can't find the right balancer tab to install on your timing cover if you are using a bastardized cover and balancer setup. Basic idea is to dial the light til the 0 mark on the balancer crosses the zero mark on the timing tab. Then you look at the dial and you read your advance off the dial. But you still disconnect the bypass wire to set base timing, because the idea is to set base timing. If you keep the wire connected, the ECM advance is going to be different at different temps, etc. After you set it correctly, you could 'map' out the timing with the dial-back light. Compare different advances with vacuum readings, IAC operation, gets kinda deep, but that's stuff to mess with if you have a lot of free time and want an idle that appears to be stock with a cam that is far from it.
To ECM plug to D/C for timing
