Will a front y-pipe from an '85 fit my '88?
Re: Will a front y-pipe from an '85 fit my '88? (JCAIRE2)
Yes. :yesnod:
I just used a 85 on my 91 to get rid of the precats.
Re: Will a front y-pipe from an '85 fit my '88? (Rob 91Z07)
Thanks, that's what I wanted to hear! :cheers: :seeya :steering:
Wait John, you will need a 4 bolt flange cat or have to have the flange cut off the front Y. The 2 mounts differently at the cat.
Re: Will a front y-pipe from an '85 fit my '88? (65Z01)
It's already got the flange cut off, but I just want it to ditch the cats anyway. While I'm at it, I might replace the main cat with a test pipe, we'll see.
Thanks guys :cheers: :seeya :steering:
BAH! got outbid anyway. How much should I be willing to pay for one of these stock pieces?
[Modified by JCAIRE2, 1:03 AM 4/27/2003]
[Modified by JCAIRE2, 1:28 AM 4/27/2003]
Re: Will a front y-pipe from an '85 fit my '88? (VetteNoob)
I would think you should be able to find a stock y-pipe for nearly nothing. I got mine from a guy who upgraded his whole exhaust and he was grateful for me to take it away for free. :) Post a wanted in the C4 parts and see if you can come up w/ one. Good luck and yes it is a bit bigger diameter, but I didn't measure it. I just wanted the precats gone.
Cruise-In II Veteran
To fab a convenient "test pip" have the ends of the cat cut off and welded to the ends of a length of test pipe. That way it can be bolted up like a cat.
