EGR tube connection to Hooker 2149 Headers
Cruising
Started my Header install project.
Driver side no problems.
Late 1986 coupe aluminum factory heads, automatic.
Passenger side
EGR tube connection at exhaust manifold has a clamp ring,
Hooker 2149 have a 2 bolt flange,
Do later year corvettes use flange to flange EGR connection tubes.
Has any one ran into this problem?
Any help or part location or numbers would be greatly appreciated
[Modified by DoubleTrouble, 9:21 PM 6/1/2003]
Passenger side
Re: EGR tube connection to Hooker 2149 Headers (DoubleTrouble)
Welcome to the world of header installs and lack of information in the public. :)
Yes, you are correct on the later C4s and the EGR tube. 87 and before use a clamp ring like you have. 88 and later have a flange with a gasket and two torx bolts. I had to buy a new egr tube when I put the 2149s on my 87.
If you snag a pipe for an 88-91 you'll be good to go, but you will also need to order the EGR tube gaskets (2 of them) or make your own.
Cruising
Re: EGR tube connection to Hooker 2149 Headers (scorp508)
Scorp508
Thanks for the quick response
EGR tube would be a GM direct item or would automotive parts store carry them.
[Modified by DoubleTrouble, 9:43 PM 6/1/2003]
GM will definitely have it, but I can't find the part # in my records right now. Hopefully someone else will chime in. :yesnod: I don't know if an auto parts store will have it or not. I went to autozone once trying to get the gaskest for the tube and they looked at me like I had 3 heads.
Received 1,400 Likes
Do ya remember how much it was?
Cruising
Per scorp508 advise I called local Chevy dealer
Dealer faxed me a cut sheet for a 1988 emission.
Item # 1 Showed flange to flange EGR Tube connection.
list price $ 75.00 I got it for $ 58.00 dollars ran it through company account.
ordered gaskets, torx bolts same time. non stocking item, one day from Chicago warehouse.
Sure glad I ask the question, If I get a part number I will post
Cruising
scorp508
Thanks for the help !!
1988 EGR tube flange \ flange 11 1/2 long GM # 10055728
with aluminized cover.
list $ 75.00 Discounted was $ 58.00
Flange Gaskets GM # 1005-5726
Torx drive bolts GM # 1408-1021
There is a 15 1/2 long flanged EGR tube. Do not know which year it is off.
[Modified by DoubleTrouble, 2:09 PM 6/3/2003]
Re: (scorp508)
No, but I think I remember it being more than I thought it should be. :(
I'm at work, but I can check when I get home. I installed LT headers and did EGR delete on my 1994 about a year ago. I think the entire exhaust is still under my house. A photo of exactly what you need would help.
Gm10055728
There is eBay options for both. Use the '90+ part# 10108433 for searches and you know the earlier.
