Hard Start
Old Jul 24, 2003 | 08:37 PM
Southern Comfort's Avatar
Southern Comfort
Default Hard Start
The other day I was filling up and went to start and all I got was a click...tried again..start. so I shut it down tried again click again start.
My cranking time is increasing to about 4 seconds where it used to be almost instant. Sounds kind of weak.
Fuel, fire or Starter problem on long crank? 153k miles looks like original starter.
Old Jul 24, 2003 | 08:41 PM
HTRK-1's Avatar
HTRK-1
Default Re: Hard Start (Southern Comfort)
Clean the connections to the starter and go from there. Make sure you have full battery voltage to the starter. I'm assuming your battery is in good condition and VATS isn't the problem.
Old Jul 24, 2003 | 10:35 PM
crheinish's Avatar
crheinish
In this heat it could be a weak battery, starter, or if it cranks OK but won't start until 4 psi of oil pressure than your fuel pump relay is bad. :)
Old Jul 24, 2003 | 10:58 PM
vader86's Avatar
vader86
I would suspect some heat soak on the starter, a heat sheild would help.
Assuming the battery is good.
To Hard Start
