Winshield wiper collisions
Old Aug 5, 2003 | 07:29 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Winshield wiper collisions
I did the CF Search, read all the articles and noted the consensus solution - replace the arm and blade assemblies with those for the 1996 C4. The only problem is, I HAVE a 1996 C4. From reading the posts, I'm left with the impression that all the possible solutions discussed (re-adjust wiper adjuster arms off , set splines off by x, etc) are temporary ones that can be permanently remedied by replacing originals with the 1996. Is there anything else that can be done or should I try the above, myself? Also, I've got a really bad case of wiper blade hop and they squeak like crazy. The blades are supposedly about a month old (dealer's paperwork shows they had been replaced) and I cleaned the windshield with a dish soap solution (another suggestion in case any wax was on the glass) but they still really drag on the windshield. In fact, I'm wondering if that's why the wipers are colliding in the first place - because the blades are sticking to the glass. Any thoughts? Thanks...
Old Aug 5, 2003 | 07:36 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Winshield wiper collisions (tobijohn)
Wipe the glass off with acitone, careful not to touch anything but glass. That will get rid of ANYTHING.
After that, it's alignment/measurments......
Old Aug 5, 2003 | 09:18 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: Winshield wiper collisions (edsalinas)
buy a one inch shorter wiper blade for the drivers side. :cheers:
Old Aug 5, 2003 | 09:37 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Default Re: Winshield wiper collisions (lead foot 85 vet)
:iagree: A permanent remedy and only an NCRS member would notice. Did it on mine.
Old Aug 5, 2003 | 09:41 PM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Winshield wiper collisions (Ski2Tee)
I've got no problem with a simple solution like a shorter blade (in fact, I'd prefer it) but how do you know which shorter blade to buy?
Old Aug 5, 2003 | 10:34 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
A tip from Gordon Killebrew: Flip the wiper blades over every 30 days and they will not develop a "set". :)
Old Aug 5, 2003 | 11:15 PM
speedracer1996's Avatar
speedracer1996
I had the same problem with mine. Just get new blades. I went with a different blade design. I did this eight months ago and have had no problems since. I think that some designs grab the glass to much (i.e. too much rubber surface contact). This causes too much friction and you get the jumpy wipers and that really loud slap every now and then, man I hate that.
Nick :D
[Modified by speedracer1996, 10:16 PM 8/5/2003]
Old Aug 5, 2003 | 11:53 PM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Winshield wiper collisions (speedracer1996)
speedracer1996 wrote:
"Just get new blades. I went with a different blade design. I did this eight months ago and have had no problems since."
Do you remember the brand of the blade?
Old Aug 5, 2003 | 11:54 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I do believe the driver side has the "inside" wipe position. Meaning, when the wipers are going up the windshield, the driver side trails. Coming down the windshield, driver side leads. So go shorter on the driver side. Of course if the passenger side is actually the inside wipe position as described, then go with a shorter passenger. I'm pretty sure though that the tip of the driver side blade hits the center of the passenger blade about halfway down the windshield.
Old Aug 6, 2003 | 12:16 AM
speedracer1996
I don't remember what brand, but I do remember that it was late (and raining) and the only thing open was Walmart. I suppose they can't carry too many brands, I'd check 'em out.
Nick :thumbs:
Old Aug 6, 2003 | 12:41 AM
tobijohn's Avatar
tobijohn
Bench Racer
"I don't remember what brand, but I do remember that it was late (and raining) and the only thing open was Walmart"
Jeez, Walmart had wiper blades for a Corvette? Is that incredible or are wiper blades interchangable among many popular models of cars?
Old Aug 6, 2003 | 12:47 AM
speedracer1996
I think there is a chart or a little computer or something that gives you the part number. There arn't too many types of blades.
:D
Old Aug 6, 2003 | 12:59 AM
tobijohn's Avatar
tobijohn
Bench Racer
Thanks! Can I assume that if Walmart has them, a Pep Boys or an equivelant auto parts store would as well?
Old Aug 6, 2003 | 01:03 AM
speedracer1996
Yep, they would probably have a better selection. I like Pep Boys, but every time I go there I buy a bunch of junk I never use. It's like a kid in a candy store. :yesnod:
Old Aug 6, 2003 | 01:44 AM
tobijohn's Avatar
tobijohn
Bench Racer
"I like Pep Boys, but every time I go there I buy a bunch of junk I never use. It's like a kid in a candy store."
I know EXACTLY what you mean...
Old Aug 6, 2003 | 02:03 AM
JCAIRE2's Avatar
JCAIRE2
I believe he's referring to the rubber insert, not the replacement blade assembly. That's what I did with mine. Went with a 18" on the drivers side.
Old Aug 7, 2003 | 12:36 AM
tobijohn's Avatar
tobijohn
Bench Racer
UPDATE: I intended to order the factory replacements from Superior (local Chevy dealer wanted $29 each) but while at the Pep Boys this evening to pick up windshield wiper fluid, just to satisfy my curiosity, I asked the parts guy if they had replacement blades for a 96 Vette in stock. Not only did they have them, the parts guy went out to my car, determined that the ones on my car were new but defective, replaced them with new ones and because they were the same brand that Pep Boys carries, said he'd return them to the manufacturer and didn't charge me a cent! Hit a thunderstorm on the way home and no squeaks, no hops and no collisions. Thanks to all for the advice and help...
[Modified by tobijohn, 3:13 PM 8/7/2003]
To Winshield wiper collisions
Old Aug 7, 2003 | 12:48 AM
redvette1986's Avatar
redvette1986
I did the famous "one-inch-shorter-drivers-side-wiper" solution and it lasted two years. Now I am using the 96 conversion and they work perfectly....so far.
Best price I have found for these parts (arms and blades) is the last detail.
http://www.tld-corvette.com
Old Aug 7, 2003 | 01:51 PM
aggie88's Avatar
aggie88
Default Re: Winshield wiper collisions (redvette1986)
TLD sells arms for 95-96 Vettes. I have a 95 - put in some ANCOs - and voila - WIPER COLLISONS! They jump and chatter and then BAM!!! So, I assume getting 96 arms wont fix my problem. :confused:
Old Aug 7, 2003 | 02:24 PM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Winshield wiper collisions (aggie88)
aggie88 wrote:
"So, I assume getting 96 arms wont fix my problem."
I'm no expert but someone, somewhere mentioned that Chevy changed the wiper arm design somewhere in the 95 production run so you might already have them. If you haven't checked it out already, There's a picture of the two types side by side in a Tech Tip (https://www.corvetteforum.com/techtips/viewsubtopic.php?SubTopicID=42&TopicID=2 ). I just looked and I couldn't see any name on the new blades but I believe the parts guy said they were ANCo as were the ones that went bad. New ones fixed my problem...
