heads
Old Aug 8, 2003 | 12:22 PM
devilfish's Avatar
devilfish
Default heads
best heads for a miniramed l98 with hotcam kit and headers?
thanks
Old Aug 8, 2003 | 12:28 PM
Raistlin's Avatar
Raistlin
Default Re: heads (devilfish)
AFR 195's
Trick Flow 23*
disclaimer: I have used neither product
Old Aug 8, 2003 | 12:36 PM
devilfish's Avatar
devilfish
Default Re: heads (Raistlin)
hmm. ok
anyone else?
Old Aug 8, 2003 | 01:31 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Trickflows are great heads for the money
If money isn't a consern then AFR's all the way!
BTW, I'm using Trickflows, great heads! :yesnod:
Old Aug 8, 2003 | 01:38 PM
jerkyboy's Avatar
jerkyboy
Default Re: heads (NUckINg FuTS)
I am having the MORE Performance L98 Top end kit (miniram etc..) installed as we speak. Using Dart Pro 1 that I believe are 220cc. In a couple of weeks, I'll let you know how they do.
Old Aug 8, 2003 | 01:39 PM
mos90's Avatar
mos90
Default Re: heads (jerkyboy)
if more per. is making you package he uses afr 195s now. 220s would be much to big for 350ci.
Old Aug 8, 2003 | 01:41 PM
mos90's Avatar
mos90
tpis makes a version on the afrs they are 187cc and combustion chamber from 50-54. that is the way to go if you have 1800.00
Old Aug 8, 2003 | 01:53 PM
jerkyboy's Avatar
jerkyboy
Default Re: heads (mos90)
Nope, I know for a fact they are Dart Heads. I just can't remember size. I know they are over 200cc. We're going with a big cam, 30# injectors, pump, the whole thing. Lower gears too. They may have said they are going to AFR because my heads took forever to get. :mad
Old Aug 8, 2003 | 01:56 PM
devilfish's Avatar
devilfish
nice keep us updated :)
How mych better will the trick flow heads be compared to my LPE ported 11`3 heads?
Old Aug 8, 2003 | 04:57 PM
loiq's Avatar
loiq
grumpyvette has Trick Flows and he said he had to port them to get them to flow as good as the AFR 195. You may want to IM him or e-mail him, he's usually a wealth of info regarding flow numbers and package combinations and such.
:seeya
Old Aug 8, 2003 | 06:47 PM
LD85's Avatar
LD85
Could be the 215 CC thats what I have, the next size up I believe needs offsets. These puppies breath for sure!
To heads
