92 C4 brakes
Old Oct 13, 2003 | 10:04 AM
DISGOFAST's Avatar
DISGOFAST
Default 92 C4 brakes
Has anyone ever experenced brakes locking up at speed?
This weekend I was driving 80 mph and all four brakes engaged and slowed the car to a stop. after 30 min. the brakes released and the pedal went to the floor,I bleed the lines and now all I have is a brake light on the dash. As well as four shot rotors and cooked pads! What do you think?
Old Oct 13, 2003 | 10:15 AM
bogus's Avatar
bogus
Default Re: 92 C4 brakes (DISGOFAST)
booster went nuts? never heard of such a thing....
Old Oct 13, 2003 | 11:40 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Damn, ASR module went mad? :crazy: :confused:
Old Oct 13, 2003 | 01:53 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
This is a strange one, they locked up for 30 minutes then the pedal went to the floor?
Power booster/master cylinder freaked out ?
Old Oct 13, 2003 | 01:55 PM
korvette4u's Avatar
korvette4u
Default Re: 92 C4 brakes (edsalinas)
i be waiting for answer on this one too?
Old Oct 13, 2003 | 02:54 PM
DISGOFAST's Avatar
DISGOFAST
Default Re: 92 C4 brakes (korvette4u)
The car only has 21,122 miles and spends a lot of time under cover,the dealer told me the brake lines are the best place to start. He told me the lines deteriorate and cause the fluid to boil over? I asked why the brakes released after 30min. and he told me the rotors expand from heat as they cool the brakes release.
Old Oct 13, 2003 | 03:07 PM
bogus's Avatar
bogus
I don't buy that explaination... sounds like a crock...
Old Oct 13, 2003 | 03:09 PM
DISGOFAST's Avatar
DISGOFAST
Default Re: 92 C4 brakes (bogus)
I,m with you!
Old Jan 21, 2010 | 04:16 PM
alecracing's Avatar
alecracing
probably the master cylinder if ALL brakes locked up
Old Jan 22, 2010 | 09:20 AM
mashinter's Avatar
mashinter
I had this happen on a '65. I found the compensating port in the master cylinder was plugged. The compensating port is a small hole ahead of the piston seal the allows expanding fluid to flow back into the reservoir. If it's plugged, the fluid heats up and applies the brakes. As the brakes heat up the fluid expands more, and you soon get full brakes. Let 'em cool about 30 minutes and drive away. I have silicone fluid and I think that may be more prone to expand.
I was very impressed that the disc brakes on the '65 would grind the car to a halt even with full throttle on the 396 in 1st gear!
Old Jan 22, 2010 | 09:57 AM
arbee's Avatar
arbee
Someone has too much time on their hands! If I'm reading correctly, this thread is more than 6 years old.
Old Jan 22, 2010 | 10:13 AM
alecracing's Avatar
alecracing
This is my buddies car and it WAS the master cylinder (compensating port)...I didn't see this post until yesterday so I thought I would let everyone know what actually fixed it
Old Jan 22, 2010 | 10:43 AM
arbee's Avatar
arbee
Sorry, but I'm still confused. Your post #9 is the first one since October of 2003 and you are saying it is "probably" the master cylinder.
To 92 C4 brakes
