cam upgrade
Old Oct 27, 2003 | 09:03 PM
1320dance's Avatar
1320dance
Default cam upgrade
:mad new best 13.03 @ 106.69 mph, 96 lt1 mods cold air - prog III - air foil looking to port heads & intake :mad need mild cam any advise :reddevil will be adding 2500 stall this winter hoping for mid 12's in spring :jester how much more h/p from port work & cam thanks racers ( good luck )
Old Oct 27, 2003 | 09:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: cam upgrade (1320dance)
On an L98 a good cam and heads are worth 50-60chp gain.
Your current trap speed shows around 12.6sec as your ET potential; what kind of 60' times are you pulling now?
Old Oct 28, 2003 | 03:52 AM
richy rich's Avatar
richy rich
I run the ZZ-4 GM cam in my 94 auto,I think it's great,With a pcm for less program It idle's nice & has ton's of low & mid range power.
To cam upgrade
