upshift light on auto
Old Jan 12, 2004 | 07:26 PM
JackDidley's Avatar
JackDidley
Default upshift light on auto
Ie tried to make this light come on for 6 years. Thought the bulb was fried. Now @ 1800 rpm, 48mph steady cruise it comes on. What triggers it? Vacuum signal? speed sensor? Wish I had the bugs out of this new combo.
Old Jan 12, 2004 | 07:40 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: upshift light on auto (Spankyellow)
:cheers: Can't wait to see the responses you get! I think, empasis on I THINK, I saw mine come on once at 4000+ rpm in second gear (auto also)
:seeya
:steering:
Old Jan 12, 2004 | 08:04 PM
HapAFcop's Avatar
HapAFcop
Default Re: upshift light on auto (jackdaroofer)
I thought the "upshift" indicator was only for manuals. I've never seen it light up on my auto....
Old Jan 12, 2004 | 08:05 PM
bccorvette85's Avatar
bccorvette85
Hey spanky! What have you been up to. What new setup are you talking about?
Old Jan 12, 2004 | 08:22 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: upshift light on auto (HapAFcop)
:cheers: As I said..."I think I saw it come on once"...Then again I think I saw Madonna trying to flag me down :D :D
Still interested in responses to this post....just in case
:seeya
:steering:
Old Jan 12, 2004 | 08:31 PM
87vette's Avatar
87vette
Mine comes on also when I stay at a steady speed on the hightway and forget to put the car in overdrive. It comes on when I stay around 45 to 55 mph for a certain period of time. It's supposed to tell you to shift for better economy. Mine works as far as I know :yesnod:
Old Jan 12, 2004 | 08:59 PM
JackDidley's Avatar
JackDidley
Default Re: upshift light on auto (bccorvette85)
BC85, Whats up? Been working on this car for 2 weeks. Cam, heads, Intake. What a pain. Drove it to work today,first time. Still got bugs to work out..A real pain. Whats going on at your end ? Ready to drag race?? :chevy
At least Im not the only one wondering about this. I seriously thought the bulb was fried. Now the cars not running right I can make it come on at will. Does anyone really know how it works?
[Modified by Spankyellow, 8:03 PM 1/12/2004]
Old Jan 12, 2004 | 09:22 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
MIne used to come on all the time after I rebuilt the tranny. It wouldn't shift into OD until I re-adjusted the TV cable. Now I can't get it to come on.
Old Jan 12, 2004 | 09:37 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: upshift light on auto (Bruthish)
Mine seems to work. If I cruise at 51 MPH in drive, it tells me to upshift into OD.
Old Jan 12, 2004 | 09:48 PM
JackDidley's Avatar
JackDidley
Default Re: upshift light on auto (Steel Blue 91)
Maybe thats the way it should work. Mine NEVER came on before and I didnt do anything to fix it. :skep: Im confused.
Old Jan 12, 2004 | 09:52 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
the only time my upshift light came on, on my automatic, was when my ECM was fried :eek:
It should NOT come on :nonod:
Old Jan 12, 2004 | 09:57 PM
JackDidley's Avatar
JackDidley
My ecm is fried??? :eek:
Old Jan 12, 2004 | 10:13 PM
Steel Blue 91
Default Re: upshift light on auto (*89x2*)
Quote from the 91 owners manual -
"This light will come on approximately one minute after you reach crusing speed to remind you when to shift into 6 (Sixth) gear for a manual transmission and [D] (Automatic Overdrive) for an automatic transmission".
Old Jan 12, 2004 | 10:17 PM
JackDidley's Avatar
JackDidley
Finally!!! Now everybody go out and try it. Thanks Steel. :jester
Old Jan 12, 2004 | 10:51 PM
SunCr's Avatar
SunCr
Disabled at least for the '89 auto. I believe all of the digital clusters have the light (since the only differences are between cruise and non-cruise cars. Signal is sent on the serial data line (same that carries the average fuel and range info) from the ECM to the cluster. Hard to find any info about it - Killebrew barely mentions it in his cluster repair manual and I couldn't find anything in Helms. Usually, if the serial data line is whacked, you won't get the fuel info or a check engine light. Later vehicles, such as my '97 S10, use a driver circuit to ground the light instead of the serial data line to illuminate it, so analog clusters may have a different control. However, if it's not working and it's suppose to, suspect the cluster or PROM (assuming the fuel info is being displayed and it's got a check engine light).
Old Jan 12, 2004 | 10:56 PM
Tourney3p0's Avatar
Tourney3p0
Mine will come on when I'm going up a hill between 40-50 mph. There's one hill around here that it always comes on at the same spot near the top. As soon as I change my speed at all or clear the crest of the hill, the light will go away.
Old Jan 12, 2004 | 11:06 PM
SunCr's Avatar
SunCr
Default Re: upshift light on auto (SunCr)
I checked my resources for the '94 Vette - it uses a driver circuit for the upshift light, manual only.
To upshift light on auto
corvettemaster's Avatar
corvettemaster
i have an 86 A4, and mine comes on all the time in D and OD except for when the lock up torque convertor is engaged. otherwise if i'm cruising at 50+ in D it'll come on, or if i'm traveling at any speed constantly in OD :crazy: i hate it
Old Jan 13, 2004 | 08:18 AM
JackDidley's Avatar
JackDidley
SunCr, this makes sense now. I had the scan cable attached when it came on and gages behaved as you described. You definitley know your stuff. :thumbs:
Old Jan 13, 2004 | 08:43 AM
eric_daniel's Avatar
eric_daniel
Where can you get one of those "cluster repair manuals?"
