Could anyone tell me how to identify an LT-4 Knock Sensor/Module? Since I just bought my '95 and it already has a Hot Cam & Roller Rockers, I'd like to check that it already doesn't have one before I upgrade. And where is the best place to buy this from?
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Re: LT-4 Knock Sensor/Module - Do I have one? (BMarsh93)
The number for it is 16214681 but I don't remember if it's on the module itself. Seems like it would be though. You know it's located in the PCM, right? Easy to get to and check. I'm sure Superior, Sam Taylor, etc. would have a good price on one. $30 or less is a good price, I think mine was $28.
The sensors are in the block, and are the same as the LT1. The module is under the cover on the PCM. I also think it is marked on the module, but can't remember. If you send me an email I'll check my old one for you over the weekend.
Re: LT-4 Knock Sensor/Module - Do I have one? (Lone Ranger)
Thanks for everyone's help and responses.
Lone Ranger - Thanks for the picture, I really appreciate it.
I'm going to check it disconnect battery and check PCM right now.
Wish me luck.
OK check this out. I definitely don't have an LT-4 Knock Module. The PN# is 16177690. I just found this website: http://www.fbodyextreme.com/knock_module.html that says the LT1 Knock Module is this #: 16214661. Is this perhaps the # for the F-Body or should all LT1's be the same? Can anyone verify this number? Thanks.
