Axle leaking Oil
Old Apr 5, 2004 | 11:39 PM
1985vette's Avatar
1985vette
Default Axle leaking Oil
My rear axle is leaking a sizable amount of oil, im not sure for how long, I got under it and tightened some of the bolts, they were all pretty tight, but i could manage to tighten them a little more. Could that solve my leaking? or is there another common or somewhat common cause for the rear axle to leak?
Old Apr 5, 2004 | 11:53 PM
Pete K's Avatar
Pete K
Default Re: Axle leaking Oil (1985vette)
This is a good news bad news answer. The good news is about $60 is all that is needed for parts. The bad news is that the rear must come out and be separated from the bat wing to access clips to remove axle. I hope you have skill to do yourself. If not many hundreds of dollars to replace. I feel you pain.
