2000 18" rear wheels
Old Apr 19, 2004 | 02:19 PM
thejazze's Avatar
thejazze
6th Gear
Default 2000 18" rear wheels
Will the 2000 18" stock vette wheels fit on my 90' vette? I know the bolt pattern is the same.
Old Apr 19, 2004 | 02:24 PM
bogus's Avatar
bogus
Default Re: 2000 18" rear wheels (thejazze)
should.
Old Apr 19, 2004 | 02:27 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
yes. Several forum members run them.
Old Apr 19, 2004 | 03:49 PM
MYCoupe's Avatar
MYCoupe
Default Re: 2000 18" rear wheels (SurfnSun)
They will fit w/o any problems. Run a 285/35/18 tire and your speedometer will hardly be off (like less than 1 MPH @ 60 MPH). The only thing is that it will sit a little bit further inward than your current wheels. 65mm offset for the Y2Ks vs. 56mm for you stock ones. The difference works out to a little less than 3/8" so it's not really noticeable.
To 2000 18" rear wheels
